Minimalist inspiration
  • TexasKZ
  • TexasKZ's Avatar Topic Author
12 Nov 2016 06:18
#747805
A pretty interesting example of the K.I.S.S. principle.
The following user(s) said Thank You: Patton
  • loudhvx
  • loudhvx's Avatar
Re: Minimalist inspiration
12 Nov 2016 07:14 - 12 Nov 2016 07:15
#747807
Awesome... back when mustaches were required to match your handle bars.
I don't see any brakes... possibly a board track racer? Prob not, since the front fender looks pretty important.
Last edit: 12 Nov 2016 07:15 by loudhvx.
  • TexasKZ
12 Nov 2016 08:24
#747814
No apparent throttle control and the exhaust pipe is right under his elbow. Could those fat things above the front wheel really be springs, or is it some sort of primitive brake?? :blink:
  • TexasKZ
12 Nov 2016 08:25
#747815
No evidence of a clutch, either.
  • TexasKZ
12 Nov 2016 08:28
#747816
Oh, wait, could that pipe be the intake, and the exhaust exits through open ports about mid way down the cylinders in front?
WEEEHAAA!!! :woohoo:
  • loudhvx
  • loudhvx's Avatar
12 Nov 2016 09:18 - 12 Nov 2016 09:21
#747819
Yes, I think the front end is a weird type of springer. The rear half of the fender is actually supporting the swingarm for the front wheel, and the vertical contraption parallel to the steer tube must be some kind of spring.
As for the motor... your guess is as good as mine. Very cool looking, though. That thing is all motor and wheels.
No brakes, no clutch, no trans, (direct drive?) max throttle ... maybe a top-speed salt flat racer?
Maybe he gets pulled by horses to get started? :)
Last edit: 12 Nov 2016 09:21 by loudhvx.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
12 Nov 2016 10:38
#747821
No tranny, def flats or board track racer
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • Nessism
  • Nessism's Avatar
  • Nerdy
  • Nerdy's Avatar
  • Away
12 Nov 2016 14:58
#747828
Zoom in on the pic and look at the chain ans sprockets on that thing.
The sprockets look more like gears. :blink:
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
