82 kz1000 ground up build
Re: 82 kz1000 ground up build
05 Jun 2024 08:15
The following user(s) said Thank You: jowek70
- slayer61
- KZR FLAG RELAY CARRIER #62
05 Jun 2024 08:32
05 Jun 2024 09:22don't "sit on the fence" Slayer ! If you have an opinion "speak up"
The following user(s) said Thank You: Nessism, slayer61
05 Jun 2024 13:14
I would love to see a gray coloured seat cover complimented with your bike color contrast diamont stitching.like this one..
05 Jun 2024 13:46
- jowek70
06 Jun 2024 06:42 - 06 Jun 2024 06:42
haha, didnt realize seat color was so polarizing!
i'm sold on brown though, but i have the stock seat with black cover i can throw on for a photo op.
heres the seat i was thinking of....
Last edit: 06 Jun 2024 06:42 by jowek70.
06 Jun 2024 06:46
Brown seats draw almost as many opposing views as a good "oil" debate
I think that is dark enough to work with the colour scheme(I went with black on my build as I still haven't decided what the end paint scheme will be
- jowek70
06 Jun 2024 08:15
haha it would seem that way....
i've had really good experience with a shop in Vietnam that makes reproduction seats, complete for around $250 shipped.
- jowek70
20 Jun 2024 06:33
Minor updates:
ordered a few electrical parts; local shop welding up a bracket for the right side cover grommet; had to take apart the rear end as the rear caliper mount is bent, cheap fix; ordered clutch and throttle cables.
To do:
fuel system, exhaust (muffler purchase and fitment), gauge, headlight and mounts, quickshifter and dyno tuning.
To do:
20 Jun 2024 06:39
Have you come up with a resolution to the cross tube you removed from the frame ? (if not the resultant flex may break the engine mounts off of the motor)
- jowek70
20 Jun 2024 07:23
once i have the exhaust in place i'm going to see what i can do about putting the same tube back in or a smaller diameter solid shaft and weld it in place.
20 Jun 2024 09:30Could you put it back a little higher just above the headers ?once i have the exhaust in place i'm going to see what i can do about putting the same tube back in or a smaller diameter solid shaft and weld it in place.
