82 kz1000 ground up build
Re: 82 kz1000 ground up build
16 Oct 2023 15:58
The following user(s) said Thank You: jowek70
- jowek70
The following user(s) said Thank You: howardhb, Rolf1976_KZ900
- slayer61
- KZR FLAG RELAY CARRIER #62
25 Oct 2023 15:18
^^^ You have some impressive skills with the electric glue gun! Well done Sir! ^^^
- sf4t7
25 Oct 2023 19:56 - 26 Oct 2023 04:53
Yes, very nice welds. Wire or stick or TIG ?
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 26 Oct 2023 04:53 by sf4t7.
- jowek70
26 Oct 2023 06:04 - 26 Oct 2023 08:37
ha i wish those were mine; i paid a shop we use through my work $50; he used TIG and is very good at it. Up next is the lower rad mount and then a titanium header!
Last edit: 26 Oct 2023 08:37 by jowek70.
- slayer61
26 Oct 2023 07:52Come on... Surely there's a difference between stick welding where I live and where you live!ha i wish those were mine; i paid a shop we use through my work $50; he used stick and is very good at it. Up next is the lower rad mount and then a titanium header!
That looks like TIG welding over here.
- sf4t7
26 Oct 2023 08:12
A talented stick welder can make those even beads (sometimes called "a row of nickels") and they end up looking like TIG beads. The professional welder that did the crossmember in my 47 Ford hotrod used stick and they came out nice and even like that. So hats off to your welder.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- jowek70
26 Oct 2023 08:37
ah sorry i had a brain fart....it was TIG welded.
26 Oct 2023 12:10
- Kelly E
26 Oct 2023 13:30
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- Rolf1976_KZ900
27 Oct 2023 06:04
I cant weld but have to learn again. when i was 16 i learned to weld when was at a mechanical shool and we trained to make nice weld beeds ,now im 55 and remember nothing how to weld.
- jowek70
09 Nov 2023 10:58
modified the zx6r upper triple today to remove the clip on bosses and ignition switch mount. Running a keyless setup from woodcraft with a hidden killswitch and powdering the triples porche silver.
ordered tank and side cover decals and dropping tank off for derusting next week.
