restoring 81 650 need guidance
  • ogowen
  • ogowen's Avatar Topic Author
Re: restoring 81 650 need guidance
29 Jun 2016 06:00
#733231
Carbs
Attachment 20160629_075909.jpg not found
And spares
  • ogowen
29 Jun 2016 06:05
#733232
Attachment 20160629_080725.jpg not found
Spares
29 Jun 2016 06:19 - 29 Jun 2016 06:21
#733234
In the picture of the carbs it appears that the carb holder vacuum ports have tubing attached instead of being capped off (see image below). If that is true the bike won't start. Those vacuum ports must be capped so no air can be drawn in through them. Ed
Attachment 00003a-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32-33-34-35-36-37-38-39-40-41-42.jpg not found
Last edit: 29 Jun 2016 06:21 by 650ed.
  • martin_csr
  • martin_csr's Avatar
29 Jun 2016 06:44 - 29 Jun 2016 07:37
#733237
Does the bike have the stock exhaust system or a 4-1?
By any chance diid you check the numbers on the main jets? stock is 92.5. pod filters would require re-jetting, as they flow more air. larger main jets. maybe larger pilot jets. maybe raise the jet needles. air screw adjustment.
Don't overlook the carburetor synchronization. I very precisely mechanically synced mine using a pair of identical drill bits. the bike ran very good, but I vacuum synced them afterwards.
ps. that air filter appears to be in poor condition.
Last edit: 29 Jun 2016 07:37 by martin_csr.
  • ogowen
29 Jun 2016 08:13
#733243
martin_csr wrote: Does the bike have the stock exhaust system or a 4-1?
Has 4 to 1 exhaust. Spare carbs had 102.5 jets and the ones on bike had 92.5 so I switched them already. Do need synced though
  • ogowen
29 Jun 2016 08:15
#733244
And ed I did have caps for them then they must have fallen off during a ride. Tried making makeshift ones with tubing and tape :/.
  • ogowen
29 Jun 2016 08:57
#733257
Bike
Attachment 20160629_075849.jpg not found
  • martin_csr
29 Jun 2016 09:06
#733261
By ogowen: Has 4 to 1 exhaust. Spare carbs had 102.5 jets and the ones on bike had 92.5 so I switched them already. Do need synced though
You're probably going to need bigger main jets (maybe 115 to 117.5), 17.5 pilot jets & the jet needles clipped or shimmed to raise them. The stock 81 650-csr jet needles shouldn't have groove, so you'd have to use washers as shims.
Ignition system pickup plate. just an fyi. It looks like a DynaS. hopefully the bike also has new coils as well.
  • ogowen
29 Jun 2016 10:21
#733271
That big on the jets? When it was running it didn't seem too starved of gas but like I said I don't know much about it but I had read somewhere basically 1 jet size increase per "change" ie 4-1 exhaust, pods, etc. And 1 piolet size increase per 2 main increases. And yes it has dynacoils I remember him saying that's why it was parked to begin with was bad coils.
  • ogowen
29 Jun 2016 10:50
#733277
I did search the engine numbers kz650de048771 (on bike) which the number given for an 81 csr is de033101 so I'm guessing? And kz650be120257 (spare) closest I found was 81 for series numbers given for it are be124001.
  • ogowen
29 Jun 2016 13:12
#733290
Also the new ignition pickup plate is on the spare not the one on bike but bike does have new coils
  • martin_csr
29 Jun 2016 13:52 - 30 Jun 2016 13:00
#733296
By ogowen: I did search the engine numbers kz650de048771 (on bike) which the number given for an 81 csr is de033101 so I'm guessing? And kz650be120257 (spare) closest I found was 81 for series numbers given for it are be124001.
82 engines. KZ650DE046701- -->> 48771 is after 46701 but before 51401 (83), so the one on the bike is an 82.
The 82-83 had larger carburetor holders.
I think the spare engine is from a 77-80 650, possibly from a 79 650-C3. note roller cam chain in pic.
You should also check the frame number. the date of mfg isn't necessarily the model year.
Main jets & air filters. 102.5 are probably too small. If the air filters are old & clogged, that'll affect how it runs, especially cheap pod filters. some have to be tossed after use. others can be cleaned. some may need to be oiled with air filter oil.
Last edit: 30 Jun 2016 13:00 by martin_csr.
