1981 GPz1100 first big project
  • flhwesty
  • flhwesty's Avatar Topic Author
27 Mar 2016 06:23
#717545
Bought a 1981 GPz1100 this weekend. Over paid, never considered the amount of money and TIME it will take to finish, still do not regret buying it.
A little about it:
1. PO says it been sitting 3 years, it has been sitting much longer!! tires are cracked. Has been stored inside.
2.Has some broken exhaust studs that really worry me.
3. Has original fuel injection. PO says it ran, but he had some kind of knob installed that increases the RPM while riding or it sputters???
Going try and fire it up with FI, but plan on putting 29s on it. This will be all new to me and I am looking forward to it. Will be asking a lot of questions.
i will gladly take any advise given!!
Attachment DSCF2993.jpg not found
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
1981 GPz1100 KZ1100-B1
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: 1981 GPz1100 first big project
27 Mar 2016 06:27
#717547
Nice find...I love the GPz's... :)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • TexasKZ
  • TexasKZ's Avatar
27 Mar 2016 06:34
#717548
Sweet. If you are planning to keep the engine stock, the FI can be saved in most cases. If you are going to carbs, you may want to consider something more modern. Carbs have improved considerably since the 1970s.
  • flhwesty
27 Mar 2016 06:35
#717550
Is there any articles or sites that goes through the FI to carb swap?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
  • flhwesty
27 Mar 2016 06:44
#717551
TexasKZ what do you recommend? I have a set of 29s from WG here now, but I am not against getting better. I figure I will be into this bike way more than I will get out of it!!!!!
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
27 Mar 2016 08:24
#717580
flhwesty wrote: Is there any articles or sites that goes through the FI to carb swap?
I am certain that this has been discussed on a number of threads in KZR...but they may be difficult to tease out of the archives...the biggest issue is using the head as the injectors mount directly to the head...hence the injector ports have to be plugged.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • davido
  • davido's Avatar
27 Mar 2016 09:28
#717585
Looks like a nice clean example from the photo. Hopefully you can get it sorted without too much drama. Good luck with it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • pete greek1
  • pete greek1's Avatar
27 Mar 2016 10:07
#717592
Nice bike, if you get the FI worked out it'll run better than throwing the 29's on it, & like Texas KZ mentioned, you're better of selling those 40 yr. old carbs & getting some brand new Mikuni RS 34's, if you insist on putting carbs on it, you can probably get more than 600.00 for the 29's maybe more if they were done by WG
You can get a new set of RS 34's for around 700.00 if you shop around, & they'll be new & easy to get parts for, if need be in the future
Pete
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
27 Mar 2016 10:16
#717594
Nice find!
Also have a fondness for the GPzs.
B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • flhwesty
30 Mar 2016 14:57
#718309
My intention is to switch to carbs. If i disconnect the fuel injection harness will the plugs still fire?
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Mar 2016 15:23
#718311
Nice bike. You may have to go with a Dyna system and coils. I agree with the newer carbs. 29's will work but they can be tough to get right.
  • flhwesty
30 Mar 2016 17:07
#718349
At this point i have to go with the 29s because i have them now. If I am successful in b ringing it back to life I will probably get newer carbs. I am going to put a battery in this weekend and see if I have spark. Then disconnect FI harness and see if I still have spark. Only way I can think of doing it.
1983 GPZ750
1977 KZ1000LTD
1978 Z1R
