- Thank you received: 4
GPZ 1100 resto mod 'Old Red'
- diego092409
09 Feb 2016 16:17 #710210
by diego092409
1982 KZ1100 B2 - 'Old Red' kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
GPZ 1100 resto mod 'Old Red' was created by diego092409
After a couple years of planning, I have finally began the resto mod project on my beloved 1982 GPZ 1100 that I affectionately call 'Old Red'.
I bought the front end and rear end off of a 2006 GSXR 600. My inspiration was user JARRAD's new project/old skool project. I am using the GSXR 600's wheels in lieu of the wire wheels on jarrad's
all credit to jarrad and apologize profusely in advance for plagiarizing his PhotoShop
2015 BMW K1600GT
- diego092409
09 Feb 2016 16:36 #710216
by diego092409
2015 BMW K1600GT
Replied by diego092409 on topic GPZ 1100 resto mod 'Old Red'
Here are pics from the swap of swing arm starting. Had the spacers made almost 2 years ago by a vendor at work. I thought the space was 9.75" and had offset the swing arm to the left to create the clearance for chain. Unfortunately it was 9.25''. I cut it down and faced them up.
I fabbed up the upper shock mount and welded it in. The front end went in with the all balls bearings swap.
Everything has gone smoothly thanks to all the information I have gleaned on this wonderful community.
2015 BMW K1600GT
- diego092409
09 Feb 2016 16:43 - 09 Feb 2016 16:44 #710218
by diego092409
2015 BMW K1600GT
My next hurdle is the linkage back to the centerstand cross member. I believe I will be putting new 12 mm wide ears (1/2" ground down to 12 mm) with a clevis on the new ears and rod ends on the gixxer linkage.
2015 BMW K1600GT
Last edit: 09 Feb 2016 16:44 by diego092409. Reason: adding pic
- larriken
- Thank you received: 61
09 Feb 2016 21:27 #710240
by larriken
Replied by larriken on topic GPZ 1100 resto mod 'Old Red'
- diego092409
10 Feb 2016 01:11 #710245
by diego092409
2015 BMW K1600GT
Oh man, that's a shame. Hopefully, I don't run into the same road block. I wondered what had happend. I am hoping to make it a runner and get a lot of the kinks out before tearing it back down for paint.
2015 BMW K1600GT
- kztwin750
- Thank you received: 7
10 Feb 2016 06:10 #710262
by kztwin750
Replied by kztwin750 on topic GPZ 1100 resto mod 'Old Red'
Onboard. I dig Gpz's.
- diego092409
16 Feb 2016 12:59 #710943
by diego092409
2015 BMW K1600GT
Does anyone have a source for drop/gull wing top triple clamps? i have seen them in other builds, but can't remember who had made them? Leon?
2015 BMW K1600GT
- Thank you received: 797
17 Feb 2016 07:00 #711055
by 531blackbanshee
Replied by 531blackbanshee on topic GPZ 1100 resto mod 'Old Red'
forum member les holt has cnc'd some out.
not sure if he's back up and running yet tho.
might pm him and inquire.
- diego092409
17 Feb 2016 09:37 #711085
by diego092409
2015 BMW K1600GT
Thanks for the heads up. I hope to have the linkages for the monoshock installed this week. once I look at it's stance, I will decide what I want to do. I would like to a top triple that actually accepted handlebars and didn't say suzuki. I will have to do something. just not sure what yet.
Parts for the linkages are on their way, just need to fab up tabs on the centerstand cross member.
2015 BMW K1600GT
17 Feb 2016 13:32 - 17 Feb 2016 13:32 #711126
by 531blackbanshee
not sure what year front end you have.
but i purchased an upper triple from these guys for a busa front end on a cb750 i am building for a customer.
cognitomoto.com/collections/fork-convers...mplete-triple-clamps
and was very pleased with the whole deal and will do business with them in the future.
hth,
hth,
Last edit: 17 Feb 2016 13:32 by 531blackbanshee.
- diego092409
17 Feb 2016 19:01 #711192
by diego092409
2015 BMW K1600GT
I have seen their triple tops. They are definitely my first option. The more I think about it, the more I wish I had and mill and a late to fab up my little tidbits.
2015 BMW K1600GT
- diego092409
23 Feb 2016 19:31 - 23 Feb 2016 19:38 #712224
by diego092409
2015 BMW K1600GT
Spent some time this weekend and today getting the bottom tension linkage lugs and tension linkages installed. I got the parts at Midwest controls. I made it adjustable so that I adjust the rear height. I am not proud of the weld quality but it should hold. Next move will be to pull the swing arm and scrub off the rear tabs for the old footrests/exhaust supports and clearance the for the chain at the frame.
Has anyone done a similar rear swap with a gsxr swing arm? I am looking at drive sprocket options out there. Does anyone have a ballpark offset that I will need?
2015 BMW K1600GT
Last edit: 23 Feb 2016 19:38 by diego092409.
