1982 KZ1000 Project
  • jmartin1110
  • jmartin1110's Avatar Topic Author
Re: Re:1982 KZ1000 Project
08 Dec 2015 09:51
#702412
Thank you. It was an honor and a privilege. I am still in the National Guard and probably will retire from it. The benefits are too hard to pass up. Was in Baghdad from Dec 09-July 10.
I plan on running an oil cooler on this bike but had read that it could keep the engine too cool. So I picked up used Mocal t stat for pretty cheap. I still have to buy the cooler lines and fitting for the bike but it's a little at a time now.
1982 KZ1000 LTD (in progress)
1981 Honda CB750F
2010 Honda Stateline VT1300
  • jmartin1110
Re: 1982 KZ1000 Project
13 Dec 2015 14:43
#703019
Got the engine painted. I plan on sanding the fin edges back just figured i would let the paint cure a bit more. Also got a water/air seperator for my compressor so i will be blasting the frame soon. Once its blasted and painted i will put the motor in and will have something looking like a bike!!
Attachment IMG_0259.jpg not found
Attachment IMG_0260.jpg not found
1981 Honda CB750F
  • jmartin1110
20 Dec 2015 12:38 - 20 Dec 2015 12:41
#703768
Got some work done. I got the rear wheel centered up with the frame.
Got the wheels blasted and painted. (Only remembered to take a picture of the rear wheel)
Attachment IMG_0309.jpg not found
Attachment IMG_0310-2.jpg not found
Got the brake stay fabbed up. Still have to finish welding
Attachment IMG_0311-2.jpg not found
1981 Honda CB750F
Last edit: 20 Dec 2015 12:41 by jmartin1110.
  • jmartin1110
20 Dec 2015 12:42
#703770
I dont understand why all the pictures showed up sideways
1981 Honda CB750F
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
21 Dec 2015 03:31
#703823
nice progress your makin there.
as far as the pics,i wonder what size they are?
if the width and height are mixed up?
i always set my pics to 819 height x 1089 width
keep us posted,
  • jmartin1110
21 Dec 2015 10:38
#703874
I'm not sure what size they are but that could be why the flipped. I'll probably just stick to photobucket instead of hosting them through the forum. So far I'm very pleased with how it's coming along. Will be painting all the body work jade metallic to match the ZRX cowl that I have.
1981 Honda CB750F
  • jmartin1110
22 Dec 2015 15:47
#704008
Started working on prepping the frame to be blasted
[IMG
1981 Honda CB750F
  • jmartin1110
27 Dec 2015 12:22
#704565
Frame blasted and painted. Also got a wire harness off of ebay thats in prety good shape.
Attachment IMG_0357.jpg not found
Attachment IMG_0358.jpg not found
1981 Honda CB750F
  • jmartin1110
27 Dec 2015 14:10
#704573
Got the motor in
Attachment IMG_0364.jpg not found
Attachment IMG_0366.jpg not found
1981 Honda CB750F
  • jmartin1110
07 Jan 2016 15:47
#705920
Got the forks today. Dont mind the gold wall tires. That front tire is shot so I didnt see a point in removing it when I painted the wheel.
Attachment IMG_0401.jpg not found
Attachment IMG_0402.jpg not found
1981 Honda CB750F
  • spdygon
  • spdygon's Avatar
08 Jan 2016 12:21
#705986
Wow...looking great.
What bike are those wheels from?
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
  • jmartin1110
08 Jan 2016 16:01
#706011
They are off of a CBR 900RR. I will also be running the hydraulic clutch off of a ZX7. The bolt holes line up perfectly. I will have to remove quite a bit from the inside of the cover to make it work.
1981 Honda CB750F
