1981 750E2
  • DobbinsCMA
  • DobbinsCMA's Avatar Topic Author
1981 750E2
04 Oct 2015 11:45
#693299
Since the 440 has a bent valve and no title, it goes on the back burner. The 750 is a great super stock bike with all the stickers and only 10,000 miles. Has some electrical work to be done but all original screws are intact on the motor. Only thing that has been touched is the chain and tires. Also no turn signals. Would love some help getting it started.
Good.
Plugs changed,
new battery,
(old one has 6 v so maybe can be topped off and charged?),
Tires and chain/sprockets are good.
Oil changed
Bad.
Carbs are dirty and need of some cleaning
Some spark on two plugs, no spark on another
Weak Turnover
Valve condition unknown
timing advancer cover seems to have been messed with.
Ways to fix the spark? Is it the plug wires or the coils? One side wasnt sparking and the wires into the coil were reversed.
Also I am draining the battery so i have to get a charger for it. Any ideas?
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: 1981 750E2
04 Oct 2015 11:58
#693300
check your coil connections. I traced a no spark condition to the positive to the coil being disconnected. make sure you are getting close to battery voltage at the coil. If not, start tracing it back... Good luck. It is a great looking bike.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • DobbinsCMA
Re: 1981 750E2
04 Oct 2015 12:03
#693301
Ok I am not very good with electrics. I have seen three other threads and read the manual concerning the IC system check. How do i check voltage at the coil?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • ThatGPzGuy
Re: 1981 750E2
04 Oct 2015 12:30
#693305
Your coils have three wires: The Primary which goes to the spark plug and a positive and a negative. Check the positive wire (probably red) and the negative for 12V or close to battery voltage. Your key has to be in the on position.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • DobbinsCMA
Re: 1981 750E2
04 Oct 2015 12:30
#693306
www.kzrider.com/forum/4-electrical/38957...igniton-coil-testing
What does the poster mean when they say in #1 "1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS."
Do they mean under the tank or under the seat? and where is there a four pin connector ?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • DobbinsCMA
Re: 1981 750E2
04 Oct 2015 12:44
#693307
ok so i checked the primary side and got 3.5 on both but nothing on the secondary side. I checked the secondary at the coil not at the end of the boots cuz i wasnt getting a reading at 20K olms.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • DobbinsCMA
Re: 1981 750E2
04 Oct 2015 13:03
#693312
I didnt get a reading at all.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • missionkz
  • missionkz's Avatar
Re: 1981 750E2
04 Oct 2015 13:12 - 04 Oct 2015 13:14
#693314
ThatGPzGuy wrote: Your coils have three wires: The Primary which goes to the spark plug and a positive and a negative. Check the positive wire (probably red) and the negative for 12V or close to battery voltage. Your key has to be in the on position.
Oops, not quite right! Lol
The primary is the winding which has battery voltage applied and the grounded side which will be connected to ground through the points or a solid state circuit where the advance mechanism is. The secondary is the spark plug wire(s).
Primary will be very low DC resistance like 2 Ohms to 5 Ohms. Etc
The secondary will be high resistance like 15,000 to 24,000 Ohms.
Don't check resistance with the coil connected to anything...especially with the ignition on!! Pull the primary wires off to be sure.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 04 Oct 2015 13:14 by missionkz.
  • DobbinsCMA
Re: 1981 750E2
04 Oct 2015 14:12
#693318
yah i didnt get a reading with the secondary. I checked my kz440 with a new (i think new) coil and i didnt get a secondary either. Both Bad?
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • ThatGPzGuy
Re: 1981 750E2
04 Oct 2015 14:26
#693321
missionkz wrote: Oops, not quite right! Lol
Right. I should have said HT lead goes to the spark plug. Thanks for correcting me.
Like I said I had the same situation where two cylinders were not firing and it was because one of the coil connections had come loose. I always like to check the simple things first.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • missionkz
Re: 1981 750E2
04 Oct 2015 14:30 - 04 Oct 2015 14:32
#693324
DobbinsCMA wrote: yah i didnt get a reading with the secondary. I checked my kz440 with a new (i think new) coil and i didnt get a secondary either. Both Bad?
coul be.... Did you connect the ohm meter between both spark plug wires on one coil? The secondary on at dual coil is from plug wire to plug wire.
Bruce
1977 KZ1000A1
Last edit: 04 Oct 2015 14:32 by missionkz.
  • DobbinsCMA
Re: 1981 750E2
04 Oct 2015 15:00 - 04 Oct 2015 15:05
#693334
I did not...They came out to be in the 11s. So it seems the boot wires are to blame! thank god.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
Last edit: 04 Oct 2015 15:05 by DobbinsCMA.
