1983 ZN1300 Street fighter build.
  • Nick89
  • Nick89's Avatar Topic Author
Re: 1983 ZN1300 Street fighter build.
28 Aug 2015 16:40
#687529
Got compression and spark now. Decided to buy some KZ1300 carburetors to replace the fuel injection system. The old fuel injection is batch fire and very hard v to tune.
  • Nick89
14 Sep 2015 17:55
#690102
Update.
Got the bike to start and run for 30 seconds! Sorry was to excited for a video.
Built/building a custom wiring harness.
There will be three wiring harness's in the bike:
* Main Bike harness (Headlights, turn signals, switches)Wired but not wrapped/heat shrinked
* Ignition harness (Coil power wires, coil pickup, vacuum sensor)Finished!
* Charging system harness (Stator power wires, Mosfet Regulator wires)Not started
I will be upgrading the old Regulator/rectifier system to a Mosfet Regulator/rectifier system.
Taken just after it started and ran!
Attachment 20150911_165754.jpg not found
You can see the custom wiring harness in disarray. It is actually all wired up, I just need to wrap it up and solder the connections.
  • Nick89
14 Sep 2015 17:57
#690103
Testing custom built wiring harness
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Sep 2015 18:33
#690107
Clean up all that spaghetti and get her moving. I want to see her run. :woohoo:
  • Nick89
14 Sep 2015 19:00
#690111
Working on it!
  • Nick89
16 Sep 2015 18:15
#690407
Got the bike running!
  • RODZ
  • RODZ's Avatar
17 Sep 2015 02:29
#690423
Valve clearance?
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Sep 2015 03:33
#690438
Open carbs/carb sync.
  • Nick89
17 Sep 2015 06:36
#690466
Yea, I'll definitely be doing the valve clearance. I got the carbs tuned even better now it Idles great.
