My second Kz440 1981
- dom2570
09 Mar 2015 22:03
This bike had been sitting in my garage for a few weeks now, but I finally got the keys and title today, so I tore into it!
First thing I did was change out the bars, but a new battery in, and new plugs.
I was only getting fuel into one carb, so I removed the carbs and almost fell over laughing at when I saw the problem.
I got her to start but the carb that wasn't getting any fuel was now leaking.
I was super excited to see the tool kit there still. Lol I am going to cherish those KZ branded tools.
To do list
1. Clean crabs correctly
2. Oil change
3. Valve adjustment
Then idk
To do list
2. Oil change
3. Valve adjustment
Then idk
Whip it like a mule!
The following user(s) said Thank You: Randombeat, Richardb98
- dom2570
- dom2570
- dom2570
Re: Re:My second Kz440 1981
12 Mar 2015 10:12
So far I have cleaned the carbs, adjusted the valves (I hope I did it right, it seemed way to easy), replaced the front tire and got the chain cleaned and adjusted.
She fires up and runs great. I have noticed some white smoke, but am certain it is simply from the PO over filling with oil.
Next thing on the list is definitely an oil change.
- dom2570
12 Mar 2015 10:14
Went for a few short rides and was really impressed with the get up and go. This little bike might give my kz750 a run for her money.
- Lazyman06
13 Mar 2015 19:58
Looks good dude. I'm guessing one of the floats was way off?
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
- dom2570
13 Mar 2015 22:17
The PO had installed the float upside down. I'm still leaking a little gas from the carbs, but nothing a rebuild kit won't fix.
- Lazyman06
14 Mar 2015 11:25
Thought it looked off loo
- Lazyman06
14 Mar 2015 11:26
Lol*
- dom2570
16 Mar 2015 17:38
Finally figured out why the carbs were leaking. I thought it was the float bowls, but it was a bad oring on the fuel inlet.
My idle seems to stick sometimes. Any ideas as to what might cause that?
I also found a few holes in the mufflers. I'm going to switch it out with mac two to two from the other bike.
- dom2570
18 Mar 2015 19:57
Today I got the 2-2 MAC exhaust installed along with some new signals.
I fiddled around with the carbs and throttle cable and got my idle issues taken care of.
- dom2570
19 Mar 2015 20:21 - 19 Mar 2015 20:22
Sony Action Cam AS20 Test Ride, KZ440:
Testing out a new toy
Last edit: 19 Mar 2015 20:22 by dom2570.
