1976 KZ750B1 Cafe Project
- Steve AZ
12 Nov 2014 19:11
New to the forum and new to KZ's. Got a nicely running 1976 KZ750B1 on the cheap and plan to do a Cafe project. I have a few initial questions.
What are a few of the ESSENTIAL things to check out or replace/modify mechanically or electrically with the bike? Mostly looking for trouble spots, every bike has them. Don't want to do a full project and miss something stupid.
Doing a Cafe, any must do's or must NOT do's? (Could be subjective I suppose)
Anyone use the M-Unit? Is it worth it? (subjective again)
Has 2 into 1 header. Should I keep it? If so, what is a good muffler for it?
That's it for now, Thanks
Attachment ImageUploadedByTapatalk1415848138.674127.jpg not found
Attachment ImageUploadedByTapatalk1415848158.660384.jpg not found
Attachment ImageUploadedByTapatalk1415848167.873065.jpg not found
Phoenix, Az
1976 KZ750B1
1994 Moto Guzzi California 1100i
1971 Moto Guzzi ElDorado 850
1976 KZ750B1
Re: 1976 KZ750B1 Cafe Project
12 Nov 2014 19:13 - 12 Nov 2014 19:14
Welcome aboard!
I can't say much about cafe do's & don'ts, but here are some tips that you may find helpful:
Many newbies and not so newbies run into or issues with their bikes which could be easily avoided with a little preparation or information. Here are a couple recommendations that I hope you will find useful.
Before riding your KZ you should take a little time to become familiar with it. Simple things like checking the oil, tire pressures, etc. are explained in the Kawasaki Owner's Manual. If you bike didn't come with one (they normally are in a little holder on the bottom of the seat) you can usually find one on eBay - be sure to get one for your exact year/model.
MANUAL
You really should consider buying the Kawasaki Factory Service Manual for your bike. The factory service manual provides instructions on the various maintenance procedures and schedules for your bike, procedures for diagnosing problems, proper torque values for the various fasteners (VERY IMPORTANT), and insight into how each system on your bike works even if you are not repairing that system. Studying the manual before you attempt performing service on your bike will impart an understanding of the system you are working on which will increase the odds of success.
The manuals usually are readily available for most models on eBay and other sources; but be sure to get one that has your specific year and model in it as there are differences between the various KZ650 models. I do not recommend Clymers, Haynes, or other aftermarket manuals as I have seen instances where they provide inaccurate advice. You may decide to use those to supplement the factory manual, but in my opinion they are not a suitable substitute. If you have trouble finding one for your model ask us to help.
TOOLS
WARNING! Do not even try to use Phillips screwdrivers on the Kawasaki cross head screws. Despite their appearance they are not Phillips screws. They are Japanese Industrial Standard (JIS) screws. The tips of Phillips screwdrivers are too long & pointed to allow the 4 blades of the screwdriver to properly engage the screws, so when you apply force the screw head slots will deform and look like crap. The fact is that Phillips screws were deliberately designed to have the screwdriver bit "cam out." This was done to prevent production line assembly from over-tightening, stripping, or breaking the screws. JIS screws do not have this problem. A proper fitting JIS bit can tighten a JIS screw to and beyond the torque spec without camming out. Here's the good news - you can easily modify standard Phillips screwdriver tips to fit the JIS screws.
I have ground down the tips of DeWalt #2 and DeWalt #3 Phillips to make them fit JIS screws. The large crosshead screws on the cases take modified #3 bits (or genuine #3 JIS bits). To modify the DeWalt bits you need to grind the very tip a little, then test fit, then grind a little more and test fit, etc. until the bit no longer "rocks" back and forth in the screwhead. Picture 1 below shows how a DeWalt #3 bit fits the case screws of my KZ650 after being ground properly. The #2 DeWalt bits can be modified the same way to fit smaller JIS screws. Pictures 2 and 3 below shows DeWalt #2 and #3 modified bits.
I did find a place that sells authentic JIS bits. They don't list the #3 bit, but if you contact them they can provide the #3 JIS bits even though they are not listed on the website. These folks were very easy to work with, and the authentic bits do work great. Here's their site:
www.rjrcooltools.com/shop_item_detail.cfm?subcat_ID=89
Pictures 4 & 5 below show a comparison between my home made modified bits with the authentic JIS bits.
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
Consider buying a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
Good luck with your bike. Ed
MANUAL
TOOLS
PICTURE 1
PICTURE 2
PICTURE 3
PICTURE 4
PICTURE 5
MOTOR OIL
Last edit: 12 Nov 2014 19:14 by 650ed.
- Steve AZ
Re: Re:1976 KZ750B1 Cafe Project
12 Nov 2014 19:25
Great info on the JIS heads!! Thanks
Phoenix, Az
1976 KZ750B1
1976 KZ750B1
- 80B4
13 Nov 2014 10:08
ESSENTIAL things to check out:
Inspect the starter clutch, the bolts that hold them together back out and can cause damage.
Up grade the steering head bearings to tapered roller bearings ( All Balls has a kit)and replace the swing arm bushings to either bronze bushings or needle bearings. I found a needle bearing kit on Ebay for about $50.00.
Clean all of the electrical connections and clean and lube all of the switches.
The carbs use Mikuni N100.606 pilot jets as main jets and BS 30/96 pilot jets as pilot jets. You may need to rejet if you keep the pods and pipe. Both are available from Jets R Us at www.jetsrus.com/index.html
If you need diaphrams for the carbs JBM Industries makes them and they are cheep. jbmindustries.com/index.html
Service the brakes. I am installing braded lines and a front master cylinder from a KLR650 on my 750b3.
The rear master cylinder is NLA from Kawasaki, I am using on from a YZF600r Yamaha, it was cheep from Ebay. I had to use some of the 750b linkage and improvise but it is the same size bore and it bolts up nice.
The hydraulic switch for the front brake was bad on my 750b3 so I am using the KLR650 mechanical switch.
You will need new clutch springs. EBC makes some that work well.
Use a good quality O or X ring chain and Sunstar steel sprockets. Keep the chain adjusted correctly. If you let it get too loose it will feel like it is vibrating more.
I am using the clutch lever assembly from a Ninja 500. It is a better part and it has an adjustable lever.
Cafe do's and don'ts:
I am using "superbike bars" with the stock foot rests. Clubman bars are very uncomfortable if used with the stock footrests. I fill my bars with lead shot and install heavy bar-ends to lessen the felt vibration.
These folks make nice stainless steel bar-end weights. www.manicsalamander.com/home.aspx
Service the suspension, buy some quality shocks. I am using Ikon shocks on mine. Rebuild the forks and install fresh springs.
The M-Unit looks interesting and there are some here that are using it on their projects. I think up-grading to a modern fuse block will be solve a bunch of problems.
The 2 into 1 header works and I have one, it's a Mac I think. I understand that the stock header with the under engine cross over and a pair of free flowing mufflers will produce more mid range power. I am planning to build a stainless 2 into 2 for mine and I am looking at a pair of the Cone Engineering mufflers. I am sure I'll end up with a $200 bike that has a $1000 exhaust system.
Z1 has most of the maintenance supplies you will need. Jeff is a nice guy and he does good business.
www.z1enterprises.com/
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
