New to Forum and new project KZ650-C2
  • KawC2
  • KawC2's Avatar Topic Author
27 Sep 2014 17:55 - 27 Sep 2014 18:09
#648980
Attachment 1.jpg not found
Attachment 2.jpg not found
I decided to ditch the fender.
Attachment 3.jpg not found
Attachment 4.jpg not found
Attachment 5.jpg not found
Hi....I'm new hear to the forum. I've been a non member and just reading and learning. So I thought it was time to show some of the tips that I had learned being in the shadows.
This is my project I've been working on for a while and am now starting to get it together slowly but surely.
Last edit: 27 Sep 2014 18:09 by KawC2. Reason: none
  • K.D. HART
  • K.D. HART's Avatar
  • KawC2
Re: New to Forum and new project KZ650-C2
28 Sep 2014 06:43 - 29 Sep 2014 07:34
#649015
Yes it is. Thought I'd do something a little different. I'm actually further along than the pic shows but didn't have time to put them all up yet. When I started I had the frame powder coated but didn't take a pic of that.
I went through the whole engine split the cases checked for all tolerances and all was ok.
Attachment 6.jpg not found
These are a set of the pumper carbs that I painted with gun paint (CeraCoat) very tough stuff.
Attachment 7.jpg not found
Attachment 8.jpg not found
Attachment 9.jpg not found
Attachment 10.jpg not found
Changed over to electronic ign.
Attachment 11.jpg not found
Last edit: 29 Sep 2014 07:34 by KawC2.
  • KawC2
28 Sep 2014 19:01 - 29 Sep 2014 07:48
#649074
Attachment 13.jpg not found
Attachment 14.jpg not found
Made a wiring harness but not installed yet.
Attachment 16.jpg not found
Need to powder coat the rear sets.
Attachment 17.jpg not found
Attachment 18.jpg not found
Attachment 19.jpg not found
Still need to powder coat the bracket for the tail light.
Attachment 20.jpg not found
Attachment 22.jpg not found
Attachment 32.jpg not found
Attachment 35.jpg not found
Attachment 39.jpg not found
Waiting for the shift linkage to finish it up.
Attachment 43.jpg not found
A few more of the project
Last edit: 29 Sep 2014 07:48 by KawC2.
  • weales
  • weales's Avatar
28 Sep 2014 20:06
#649077
Welcome to the forum and thanks for the great pics - looks really good! Interested to know what black paint you used on the motor and what preparation you did before the paint was applied. I'm about to paint my '78 Z1-R motor and am looking for options - it's in one lump, already assembled. I've roughened up the previously painted surfaces with sandpaper/wire brushes and am ready to apply colour after I give it a good washdown and maskup the unpainted bits..
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
The following user(s) said Thank You: KawC2
  • KawC2
29 Sep 2014 07:30
#649099
weales wrote: Welcome to the forum and thanks for the great pics - looks really good! Interested to know what black paint you used on the motor and what preparation you did before the paint was applied. I'm about to paint my '78 Z1-R motor and am looking for options - it's in one lump, already assembled. I've roughened up the previously painted surfaces with sandpaper/wire brushes and am ready to apply colour after I give it a good washdown and maskup the unpainted bits..
Thanks for the welcome.
The cases are painted with PJ1 from Z1 enterprises. When I had the cases apart they were sprayed and then the paint was baked on. All of the other pieces are powder coated.
  • autotech2@tx.rr.com
  • autotech2@tx.rr.com's Avatar
02 Oct 2014 16:01
#649449
Different color but I thought I add my 2-cents on engine paint. DO NOT use VHT Cast Aluminum. It turns gold when it gets hot. No problem with the Universal Aluminum.
The following user(s) said Thank You: weales
  • weales
  • weales's Avatar
02 Oct 2014 16:16
#649450
Thanks for the tip - I wasn't aware that this happens - might save a lot of disappointment for some of our our other guys.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
02 Oct 2014 18:22
#649461
I couldn't believe it either. And I'm pretty sure the manufacturer new of the problem, because they reimbursed me for the job of repainting.
  • KawC2
03 Oct 2014 06:30 - 03 Oct 2014 07:20
#649510
Here's where I was till a big setback. Still have to clean the inside of the tank, do a little body work on the tank, prep all body parts, and start painting. The color I've picked is 1976 Kawasaki KZ900 green w/gold and green pin stripping.
Attachment 62_2014-10-03.jpg not found
Last edit: 03 Oct 2014 07:20 by KawC2.
03 Oct 2014 06:57
#649512
Good Fortune! :)
  • KawC2
03 Oct 2014 07:23
#649517
Patton, Thanks
