- Thank you received: 249
CSR1000 Project Build
- kaw-a-holic
02 Sep 2015 04:40 #688277
by kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Replied by kaw-a-holic on topic CSR1000 Project Build
Well done Davido. Your solution looks great, no one would ever know.
Jon
1977 KZ1000a1
Mesa, AZ
- davido
- Thank you received: 292
02 Sep 2015 09:07 #688309
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Replied by davido on topic CSR1000 Project Build
Thanks boys.Im still a bit pissed off about it. All the hassle that went into welding the bungs on in the first place.Well, you live and learn.
Spent a bit more time on the bike today and got the exhaust hanger sorted.
A bit of steel strip. I hammered the bollocks out of it around a bit of scaffold pipe to get the loop
A piece of rubber from a pipe clamp ( Not sure if itll hold up to the heat or not)
Getting the bend right was a real pig to do but I got it in the end
Bolted onto one of the holes form the original footrest hanger.
and thats it.Pretty solid and plenty of clearence for the brake pedal
So,I can scratch that off the list.The only thing left to do on this side of the bike is a rebuild kit for the rear brake caliper. I need to identify it though so I can order the right kit. I got it when I bought the first back wheel (the 180 that I didnt use) All I know is that its from a 1980s GSXR 750 or 1100. If anyone can narrow that down it would be helpful
Thats it for now.
Thats it for now.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- pete greek1
- Thank you received: 185
02 Sep 2015 10:14 #688319
by pete greek1
Replied by pete greek1 on topic CSR1000 Project Build
davido, if the rubber doesn't hold up to the heat, another option would be this fabric that withstand temp's. up to 2000 degrees
www.google.com/url?sa=t&rct=j&q=&esrc=s&...qSZXWzo8bJ98zbLzXhvA
Pete
Pete
- davido
02 Sep 2015 11:47 #688330
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Thanks Pete. Good to Know. Its going to be a while before things heat up though. Im looking at spring/summer next year for the first
fire up.
fire up.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- kaw-a-holic
02 Sep 2015 12:41 #688335
by kaw-a-holic
Jon
1977 KZ1000a1
Mesa, AZ
I don't think that rubber is a good idea. Since 6ou are not in a hurry I would suggest welding a bung to the pipe. Just my .02
Jon
1977 KZ1000a1
Mesa, AZ
- davido
02 Sep 2015 12:47 #688336
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
No Im not going to weld on it.Thatll only bugger up the chrome and as much as I dislike chrome,thats what Ive got.Ill put some heat proof stuff in there.Maybe what Pete suggests or something like that. Im sure a bit of pipe lagging would do or even exhaust wrap.Ive got the time so, Im sure something will turn up.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- GPzMOD750
- Thank you received: 148
02 Sep 2015 13:31 #688338
by GPzMOD750
Replied by GPzMOD750 on topic Re:CSR1000 Project Build
Get a heat resistant Silicone coupling like they use for turbo intercoolers. Cut to size.
- Thank you received: 797
03 Sep 2015 06:17 #688414
by 531blackbanshee
Replied by 531blackbanshee on topic Re:CSR1000 Project Build
No eBay APP ID and/or Cert ID defined in Kunena configurationthe rubber will slowly cook down to carbon.
ask me how i know :laugh: !
as far as the caliper i am saying 1986/ 88 SUZUKI GSX-R 1100,OEM/ OE REAR BRAKE CALIPER/ SLINGSHOT GSXR750 DISC
i.e.
keep up the good work.
i.e.
- davido
09 Sep 2015 10:32 #689349
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Replied by davido on topic Re:CSR1000 Project Build
Something suitable will turn up for the pipe clamp and thank Leon on the caliper. This week,Ive been busy helping no.1 son build his first bicycle,so I havent done a lot on my bike. I did flip it over and do the second adapter plate for the rearset. I also took them both to the other workshop and ran them over the industrial manicure machine ( I forgot my heatproof gloves,so it was fun to dooooooooo!)
Anyway,I bolted them together and got them both cleaned up nicely.
The problem now though,is,I sat on the bike and my knees are very close to hitting the corners of the engine head. Not so happy with that. So it looks like Im going to have to make another set of plates to shift the rearsets further back. Bugger!
The right hand side dictates where they go, as I have to work around the exhaust,so, what Ill do is cut a couple of oversize pieces of MDF and bolt them on.Then I can screw the rearsets on in different places until I find the sweet spot. Not too far forward/backward,not too high/low and not hitting on the exhaust.
What a pig these rearsets are turning out to be.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- monkeydoodle
11 Sep 2015 06:54 #689595
by monkeydoodle
Custom Harley Chop
2004 Fazer 1000 with Ivans Full Monty kit
1980 Z750E (half way being re-born into a mix breed something)
Replied by monkeydoodle on topic CSR1000 Project Build
Bloody hell Davido - you're going some with that build, very nice. I have mine at a rolling stage but loads of other bits sorted and ready for install, one last thing that I have to sort which is being done tomorrow are the rearsets. I have 2 sets, 1 from a 95 GSXR750 and the other a 2001 R6, I prefer the R6 but due the the mounting brackets being the shape they are they maybe a but tricky to adapt to the frame (the GSXR ones fit fine but I prefer the R6) - anyway, with yours mounted where they are how comfortable are they compared to the standard ones? Also I'm in two minds to keep the Harris exhaust and may go for a Delkevic header and an after market end can, you think it'll be an issue considering you had to work around your Harris?
cheers
cheers
Custom Harley Chop
- davido
11 Sep 2015 22:26 - 11 Sep 2015 22:27 #689679
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Monkeydoodle,I was busy with the rearsets again yesterday. I took the adapter plates off,swapped them over and flipped them upside down.
Still no better.The position is not uncomfortable,its just my knees are very close to the corners of the engine.I have no seat yet so Im probably sitting a bit lower than I would on the finished bike. If im a bit higher, my knees should be further back. I cant really lower the pegs because of the exhaust and I dont think its because its a Harris.I think whatever pipe you have,it runs under the brake pedal and will have to be worked around.
Im going to leave it as it is for now but think on an alternative.If I figure something out ill let you know.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 11 Sep 2015 22:27 by davido.
- monkeydoodle
12 Sep 2015 08:11 #689740
by monkeydoodle
Custom Harley Chop
cheers buddy, I have mine sorted now, fingers crossed - I may drop the engine back in the frame tomorrow and just make sure that the gear linkage rod doesn't foul on anything ? So far the sidestand is OK.
Custom Harley Chop
