Tumbleweeds 1977 KZ650 Rebuild/Reform (Pic Heavy)
- loudhvx
Re: Tumbleweeds 1977 KZ650 Rebuild/Reform (Pic Heavy)
26 Apr 2014 09:02 - 26 Apr 2014 09:03
If it was just pods and jetting, all four plugs wouldn't look so different.
As you open a throttle, the mixture gets richer. The faster you open it, the more rich it will be. So the symptom sounds like a rich condition. Plugs 1 and 4 look super rich and wet. Is it gas or oil?
I would also swap some ignition stuff around. Because it's 1 and 4, there may be an ignition issue for those two cylinders. They share ignition parts... coils and points.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 26 Apr 2014 09:03 by loudhvx.
- Tumbleweeds
26 Apr 2014 10:11
How long do these engines usually take to warm up at idle?
On the hunt...
4/2/14-1977 KZ650 B1 17k miles
26 Apr 2014 10:18
At about 1300 rpm mine warms up enough to turn the choke all the way off and ride in about a minute or two depending on the outside air temperature. With the choke all the way off it idles at around 1000 rpm. Ed
The following user(s) said Thank You: Tumbleweeds
- Tumbleweeds
27 Apr 2014 13:01 - 27 Apr 2014 13:02
Okay update to the bogging issue. I have my pilot screws (under the carb, engine side) turned 4 turns out, and it reduces the bog. I understand that is more than double where they should be.
I am having a hard time finding out what circuit that pilot screw affects. Do I need to go bigger on the pilot again?
EDIT: 5 turns out and the condition is still getting better, almost gone.
On the hunt...
Last edit: 27 Apr 2014 13:02 by Tumbleweeds.
- Nebr_Rex
27 Apr 2014 18:48
How about cleaning your carbs. Sounds like your idle circuit is partially blocked.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Tumbleweeds
30 Apr 2014 00:02
Ok so here is the story guys, and I feel a bit dumb. As it turns out I just wasn't letting it warm up enough. I let it idle for a few minutes, and took it around the block about 10 times instead of the usual 2. On the last pass around it felt like a different machine. I set the pilot screws back at 1.5 turns out. As it is, I am pretty happy with the way it runs and will focus now on finishing the seat and brake/signals. Then it's time to paint.
I am about 95% sure I am going to do Kawasaki green.
On the hunt...
- Tumbleweeds
30 Apr 2014 10:31
Plugs are looking much better, but I still need to buy a fresh set so I can better see what the cylinders are doing.
I'm still only on a bench sync so I need to invest in some vac gauges as well.
Procrastinating the seat, and slowly trying to find/make my parts.
Attachment ImageUploadedByTapatalk1398879088.515247.jpg not found
On the hunt...
30 Apr 2014 12:26
When you look into sync gauges if you see some like the ones below I can vouch for them being excellent. Before I got these I had a set of cheapies, and one of them quickly became very inaccurate. Ed
