Replaced rusty phillips head bolts
- Derigo
02 Mar 2014 08:56 - 02 Mar 2014 08:58
Replaced phillips head engine cover bolts.
Last edit: 02 Mar 2014 08:58 by Derigo. Reason: lost an L in replaced
- Derigo
Re: Replaced rusty phillips head bolts
02 Mar 2014 09:51 - 02 Mar 2014 09:51
Kawasaki never used Phillips head bolts on KZ models; they are Japanese Industrial Standard (JIS). I just wanted to clarify that for anyone reading this who might try to tackle the original bolts/screws with a Phillips screwdriver - bad idea.
None the less, rusty bolts of any flavor look like crap, and your replacements look good.
Last edit: 02 Mar 2014 09:51 by 650ed.
- Derigo
02 Mar 2014 10:17
I'm sure they can be pounded out with an impact driver, but the problem is that the Phillips screwdriver tips are too pointy to properly seat in a JIS screw, so the crosshead slots will deform. No standard Phillips screwdriver bit will ever fit like a JIS bit or modified Phillips. Below is a picture of how they should fit. When they fit like this no impact driver is needed to remove them. Ed
Attachment ScrewdriverBit3.jpg not found
- yeekim
02 Mar 2014 12:01
- yeekim
02 Mar 2014 12:29
Impact driver isn't half so effective as the tool I pictured.
I You can't fix it with hammer, it is an electrical issue
Greetings
Greetings
Ex nihilo nihil fit!
- Derigo
02 Mar 2014 13:15 - 02 Mar 2014 13:19Attachment not found
What
Last edit: 02 Mar 2014 13:19 by Derigo. Reason: no attachment
