Need advice on 80 kz 1000
- roy-b-boy-b
Re: Need advice on 80 kz 1000
21 Jan 2014 04:35
Is this a chain drive?
- crusierlover
21 Jan 2014 04:47
Yes it is a chain drive.I appreciate these links here too.I need them since I am new with this bike.
Proud owner of 1982 650csr again soon. keeping it this time
- fitscott
21 Jan 2014 05:17
That looks like a J motor which I thought were1981 and above
- crusierlover
21 Jan 2014 05:58fitscott wrote: That looks like a J motor which I thought were1981 and above
You have a good eye.I told you I am new to these bikes.lol.I checked the title, it is an 81.
- JimB
21 Jan 2014 11:36
Another site I fould helpful was the kawasaki.com site,...look up your bike, then owner info. Then you can look up your part. Once you have it you can then drill down (maybe right click) and see what other models and years this same part was used one, So it is a good place to get cross reference info on parts.
Jim
Jim
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
- crusierlover
21 Jan 2014 15:46
These links help tremendously.Thanks guys.
- crusierlover
26 Jan 2014 03:36JimB wrote: Another site I fould helpful was the kawasaki.com site,...look up your bike, then owner info. Then you can look up your part. Once you have it you can then drill down (maybe right click) and see what other models and years this same part was used one, So it is a good place to get cross reference info on parts.
Jim
I entered kawasaki.com and it takes me to a site for new bikes
- fordtruck
26 Jan 2014 06:00
When you go to Kawasaki.com, click "Owner Info", then "Parts Diagrams", then you will select your bike info.
'77 KZ1000-MTC 1075 kit. Stage 1 port
The following user(s) said Thank You: crusierlover
- crusierlover
26 Jan 2014 07:04
found out it is actually an 81.I am trying to post pics.Dont know if i can manage several views in 1 post
Attachment IMG_20140126_0836371.jpg not found
Attachment IMG_20140126_083808.jpg not found
Attachment IMG_20140126_083828.jpg not found
Attachment IMG_20140126_083721.jpg not found
- crusierlover
26 Jan 2014 07:07
I am asking, the triangle mounts for the motor, I suppose they are mount point for highway bars? The ingenious mount for license will be removed.I showed wiring pictures, not sure which to connect for a tailight.Also he had welded a lot of extension on the brake pedal to make it go under around and visible around the vance and hines exhaust.Did not think that was necessary.I do not see a rear brakelight switch.
- crusierlover
26 Jan 2014 08:29 - 26 Jan 2014 12:23Attachment IMG_20140126_132629.jpg not found
found the plug and play loom inside the fender that looks like it plugs into a connector from the bike.that should do the tailight.Looks light the fender needs to go up a notch, but the bolt holes lined up here.maybe it has been cut off.
duh, I moved it up,looks ok now.I filled it up.Not a cloud in the sky,now wind, 70 degrees outside.Then I lost the key.My wife and I have torn the house up looking for it. Drives me crazy being so damn absent minded.
Last edit: 26 Jan 2014 12:23 by crusierlover.
- crusierlover
Re: today is the day of the start of therebuild
11 Mar 2014 05:19
Finally, good weather.Today i am going to start dismantling, rebuilding.Thanks to Brian.
