Here's my 78 KZ1000 MAJOR PROJECT
- HAFROD
Re: Here's my 78 KZ1000 MAJOR PROJECT
06 Jan 2014 10:49
Guys, look at the pic with the fenders. In between them is an air filter assembly. Is this stock or aftermarket?
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
- turboking
06 Jan 2014 11:01
after market, :dry: used mostly for choppers.........LTD fenders , ltd chain guard..... :S
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- HAFROD
09 Jan 2014 16:43
I disassembled my carbs today to get them ready for a cleaning and rebuild. When I was at my local bike salvage, I scored an original H4 headlight assembly for $20. The chrome ring has major road rash on a spot though. I dug for about an hour and never found a good ring. Looks like its gonna cost a bit over $100 to redo the carbs with new gaskets and seals.
- dkoz
09 Jan 2014 17:01
Hey half rod loos like you might have picked up a lot of projects from some wear ..( seeing you have a couple of projects going on at the same time
Like we all have. .the air filter you have thear I had on a Honda chopper twenty years back..
Not ohm..or Nos. .but brings a few bucks on ebay
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- HAFROD
12 Jan 2014 21:57 - 12 Jan 2014 22:00
Well, today was the first time I really cleared a spot out for the 1000 and went over it. My intake boots looked good until I removed them and found all of them cracked badly. I happen to have my GPz305 torn down and set the front fender on the KZ. I actually like the 305 fender on it. It looks like it will bolt on with the existing holes too. I mocked up my $20 headlight assembly. I really like the fluted headlight lens. I just need a new ring cause that one is trashed. I looked the gas tank over and I believe someone has wiped body filler over the emblem mounting. Am I right on this? There should be an indentation and threaded holes for the metal KAWASAKI badge to screw on, right? Here's the previous owners butcher job on the tail being cut off and an aweful seat pan. I texted him about the tail he cut off and he said he would look for it. Hopefully he finds it. If not, I'll fab one and weld it on. He also cut off the seat hinge tabs. I'm wanting to use a set of gauges from a GPZ550 also. I like the look of the big speedo and smaller tach. The best part is it's a Kawasaki part.
Last edit: 12 Jan 2014 22:00 by HAFROD.
- chirpy999
12 Jan 2014 23:24
Thats plenty of bike for $400. Keep posting. Itll be interesting to see you get the gpz550 clocks to work. Its an electrical tach.
- HAFROD
13 Jan 2014 05:35
Another member told me how to wire it. 3 wires to connect. Sounds simple enough but we'll see.
- HAFROD
14 Jan 2014 10:33
I noticed my rear brake lever and actuator rod was missing from the big tote. I bought a set of new drag bars and the rear brake lever and actuator arm from my local bike salvage this morning. I like the drag bars. WooHoo, my list is getting shorter slowly but surely. :woohoo:
- StreetfighterKz
15 Jan 2014 08:43
You must have one nice salvage yard near you. Keep the progress updates coming!
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- HAFROD
15 Jan 2014 10:24Yes, its the largest in OKLAHOMA and they have lots of KZs. The owner is a KZ nut. They have a restored one on the show room floor that's SWEET. He also has a large shelving unit marked Rons personal KZ parts=NO CUSTOMERSStreetfighterKz wrote: You must have one nice salvage yard near you. Keep the progress updates coming!
Later, Doug
- HAFROD
15 Jan 2014 13:04
I've had heck trying to find a GPz305 front fender in the USA to put on my KZ. The one in the pic is for my 305 I'm restoring. I found one at Willys Cycle. He's got an ebay store. He had some other 305 parts I've bought from him before. I called and asked and he had one. Its on the way!
