Clutch Actuator Extention Mod
  • hoshwan
  • hoshwan's Avatar Topic Author
05 Nov 2013 10:11
#612157
My clutch lever has always been a bit heavy, and I've been casually looking for a fix, but recently I've been teaching my girlfriend to ride and the clutch is really taking it's tole on her forearm, So i did some research into clutch actuator modifications, but couldn't find anything specifically on kz650 (79). So I went ahead and did it myself, and I thought I might share.
like many others, I made it a bolt on so I could go back to stock if i wanted. It's lengthened as much as possible without hitting the inside of the casing. the pivot is offset 5/8". The clutch feel is significantly lighter. It only took some minor adjustments at the lever to dial it in. This doesn't seem to hurt, or wear on anything in a negative way, nor is there any clutch slippage. I would definitely recommend it to anyone having similar issues.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: Clutch Actuator Extention Mod
05 Nov 2013 10:26
#612158
That's a great idea HW! I know just the bike that needs one.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Beaner242
  • Beaner242's Avatar
05 Nov 2013 13:13
#612171
Awesome job there Hoshwan. need to look and see if this is possible on my bike.
1982 KZ1000K LTD Chopper
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
05 Nov 2013 13:51
#612175
really cool thinking outside the ol' box there sir!
  • kzz1king
  • kzz1king's Avatar
05 Nov 2013 14:32
#612177
Great idea!
Wayne
Home built KZ1000 turbo setup
  • wagonmaster69
  • wagonmaster69's Avatar
  • 78 KZ1000A2 / 82 KZ1100 Spectre
05 Nov 2013 20:37
#612205
Will you be able to do that with a piece of angle stock and cut to size?
  • hoshwan
06 Nov 2013 09:29
#612235
Of course! Angle iron would be perfect. It was just easier for me to machine it out of square stock. You can cut the actuator arm in half and weld a piece in between or make it bolt on like I did. Just make sure to double check your dimensions to ensure the arm is allowed to move freely in the case.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
06 Nov 2013 10:17
#612244
Brilliant! Well done.
  • tk11b40
  • tk11b40's Avatar
08 Nov 2013 20:12
#612574
Nice work.
Suzuki GSXR 750 slabside
Ducati S4R
Husqvarna FE 350s
1986 Yamaha FZ 750
