84 KZ 700 recomendations
- jadesalem
09 Sep 2013 02:02 - 09 Sep 2013 02:05
So i have finally decided to change up my 84 kz 700 i am thinking of a 4 in 1 exhaust and the air pods what do you guys recommend for those upgrades and any other changes
Last edit: 09 Sep 2013 02:05 by jadesalem.
- geerbangr
Re: 84 KZ 700 recomendations
09 Sep 2013 03:27
Swap out some 700 parts for 900 parts
An exhaust system and a set of pods along with a re-jet should wake that little fella up a bit. Perhaps a dynatek ignition upgrade as well ??
1978 KZ 1000
I go by Jason
I go by Jason
- H1Vindicator
09 Sep 2013 09:10
900 parts? doubtful. The stock electronic ignition is fine, but new Dyna coils & new spark plug wire set would be good. Pod filters? good luck. 4-1 exhaust system? yes, but some are of poor quality. Anything that fits the KZ650/700/750, ZN700/750, ZR750 (~1993 & ~ 2002)(air cooled). You may have to fab up a muffler hanger.
09 Sep 2013 16:05jadesalem wrote: So i have finally decided to change up my 84 kz 700 i am thinking of a 4 in 1 exhaust and the air pods what do you guys recommend for those upgrades and any other changes
Pod filters are not an upgrade. Be prepared to spend lots of time fiddling with them trying to make your KZ700 run as well as it does with the airbox. This is particularly true sine your bike came equipped with CV carbs.
IMHO, the best upgrade you can do, and the most logical (to me) starting point before making any changes is to perform a top to bottom tune-up on the bike and see how well it runs. If you get it running as well as the day it left the showroom floor you should be quite happy with its performance. Ed
- Nebr_Rex
09 Sep 2013 17:02
+1 on the tune-up.
But any time you increase the engines ability to breath is an increase.
The jetting will have to be adjusted to match. There are jet kits exactly
for that purpose. They might not be spot on. Because of parts used
could be a little different. Fuel used can and is different in different
areas. Then there is altitude to take into consideration also. Pods do have
some drawbacks, they are affected to a small degree by wind and rain.
A sudden big side gust and sitting outside in the rain all day do hamper
performance.
As for people saying 'you have to mess with your jetting to get it to run
like stock' . I say THE FACTORY DID IT. Look at the '79 KZ1000s, all three
models. Especially the MKll and the ST. Same engine, same carbs, why is
the jetting different.?
performance.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Nebr_Rex
09 Sep 2013 23:15
And another thing, use K&N or Uni filters.
All the others are junk, especially when it comes
to CV carbs.
to CV carbs.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
