79 Bobber Update
  • copperhead_77
  • copperhead_77's Avatar Topic Author
79 Bobber Update
10 Aug 2013 22:28
#600738
Finally got some time to work on the bike
Attachment LHclose80.jpg not found
Attachment LHside75.jpg not found
Attachment RHside75.jpg not found
Attachment IMG_20130810_174524.jpg not found
Still on the to do list is solo seat springs, mount other shock tab, finish battery box, finish re-wiring, mount the rear fender and front brake and I have to make a pin for the gas tank cap and mount the tool box
Getting closer!!
1978 KZ650 C2/ 1979 KZ650 D2 (SR) Hybrid
Arizona
  • floivanus
  • floivanus's Avatar
Re: 79 Bobber Update
11 Aug 2013 21:42
#600923
Your shock angle seems way to steep, like more likely to bend the shocks than give you that nice boing action
Past; 78 kz1000, 83 kz550
Andrew
  • copperhead_77
12 Aug 2013 02:06
#600964
they were just the old ones I had laying around for mock up. I'll be using some Harley hard-tail struts they just have not showed up in the mail yet the shaft in the middle is 7/8 to an inch in diameter so they keep true to the path they are supposed to travel, pretty heavy duty but I see what you are saying. Another alternative I had thought about was moving the lower mount somewhere closer to the middle of the swing arm. later down the road I am going to experiment with the GSXR solo spring and swingarm.
I appreciate the input.
Arizona
