Painting carbs
  • DBICK666
  • DBICK666's Avatar Topic Author
  • 1983 kz750 ltd f-1 (shaft)
Painting carbs
17 Jul 2013 17:53
#596984
hey i was just wondering how i can paint my carbs black so they look cool anyone know the right way to do it??
  • copperhead_77
  • copperhead_77's Avatar
Re: Painting carbs
18 Jul 2013 00:32
#597041
First you want clean the outside good, I used a toothbrush and ACV,I plugged all the hole with blue shop towels and used VHT flat black. The VHT might have been overkill but I know they have quality paint. Mine were completely disassembled for a stage 3 jet kit. Really simple just time consuming, but I went over all my plugs and masking a few times, worth it though they turned flawlwss
1978 KZ650 C2/ 1979 KZ650 D2 (SR) Hybrid
Arizona
  • goodfastncheap
  • goodfastncheap's Avatar
Re: Painting carbs
18 Jul 2013 01:22
#597048
Don't even attempt it. Carbs are hard enough to get running in the first place. Seriously. PAINT your carbs? c'mon.
1979 KZ650 B3
KZ Relay Rider #54, Iowa, Nebraska and Kansas
  • bluezbike
  • bluezbike's Avatar
Re: Painting carbs
18 Jul 2013 01:32
#597052
I'd stay away from painting your carbs...the fuel will just eat up the paint and with today's ethanol based fuels it's even worse, just check out what ethanol does to rubber fuel hoses never mind paint.
79 KZ 1000 LTD
  • martin_csr
  • martin_csr's Avatar
Re: Painting carbs
18 Jul 2013 10:32 - 18 Jul 2013 10:33
#597091
Just throwing something out there... maybe someone, some time will try this... you need to find a good shop to do it.
Electroless Nickel Plating. There's an old post or two about it in the Archives of the old KZR by KraZe2.
The carb tops & bowls were done but not the bodies. The linkage parts n stuff were also done.
KraZe2's carburetors... not mine.
Last edit: 18 Jul 2013 10:33 by martin_csr.
  • DBICK666
Re: Painting carbs
18 Jul 2013 16:12
#597140
cool thanks for the feed back ill check it out and goodfanstncheap.... suck it!
  • martin_csr
Re: Painting carbs
18 Jul 2013 16:36
#597149
Didn't some models come stock w black carbs? How about using a spray gun & polyurethane? Or paint them w VHT & topcoat w a 2k clear?
  • Tusch
  • Tusch's Avatar
Re: Painting carbs
19 Jul 2013 00:23
#597233
Gpz's are stock painted black. Its a great look with a blacked out engine.
1983 GPZ550
