83 KZ750 LTD
  • 2ndgenKZ
  • 2ndgenKZ's Avatar Topic Author
  • 750 LTD
83 KZ750 LTD
30 Jun 2013 22:45
#594528
Its going down, it's taking it's time, I'm taking mine.
Attachment WP_20130630_019.jpg not found
Attachment WP_20130630_021.jpg not found
1983 Kawasaki KZ750 LTD MAC
1983 Kawasaki KZ750 LTD BONES
1981 KZ750E KERKER
1985 Dodge Conquest FLATTY
1995 Jeep Cherokee RUSTY
  • 2ndgenKZ
  • 750 LTD
Re: 83 KZ750 LTD
30 Jun 2013 23:29
#594535
83 KZ750 LTD F1
Pods
Jets 140/60
I believe MAC 4-1
Orange Tank needs to be dipped. Mod to fit regular gas cap, needs petcock rebuild.
Stock LTD tank was dipped, awaiting to be surfaced and painted. Petcock rebuilt then carb one overflowed. Going through them tonight.
Cylinder three does not fire, waiting to get my hands on an adapter for compression tester. Plenty of spark. Hoping for the best.
When I picked her up
Attachment IMAG0164_2013-06-30.jpg not found
1981 KZ750E KERKER
  • 2ndgenKZ
  • 750 LTD
Re: 83 KZ750 LTD
30 Jun 2013 23:39
#594538
Past look, Kerker went to my dad for fathers day.
Attachment IMAG0203.jpg not found
Removed all black paint. Wheels, tank, Brake master cylinder
Painted headlight, turn signals, side panels. Want to do turn/signal/stop taillight.
Wait 'til you see what I'm doing with paint. MT1 Scheme
1981 KZ750E KERKER
  • 2ndgenKZ
  • 750 LTD
Re: 83 KZ750 LTD
30 Jun 2013 23:41
#594540
Attachment WP_20130630_017.jpg not found
Attachment WP_20130630_016.jpg not found
Attachment WP_20130630_011.jpg not found
1981 KZ750E KERKER
  • 2ndgenKZ
  • 750 LTD
Re: 83 KZ750 LTD
30 Jun 2013 23:53
#594542
Problem with Starter Clutch was fun. Replaced whole secondary shaft from donor motor.
Resealed cam cover.
Attachment IMAG0196.jpg not found
Attachment IMAG0197.jpg not found
Attachment IMAG0192.jpg not found
1981 KZ750E KERKER
  • OKC_Kent
  • OKC_Kent's Avatar
Re: 83 KZ750 LTD
01 Jul 2013 13:57
#594603
Keep going, looks good.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • randysway223
  • randysway223's Avatar
Re: 83 KZ750 LTD
01 Jul 2013 16:40
#594617
Looks impressive. At least all the gear stuff looks clean. keep the updates coming
  • 2ndgenKZ
  • 750 LTD
Re: 83 KZ750 LTD
01 Jul 2013 22:18
#594647
Thanks guys.
Found some more pictures from when I was placing the secondary shaft, waiting for parts. If you replace the secondary shaft, get a clutch holder, don't try to use spanner wrench, had to replace clutch hub after breaking two tabs off.
Attachment IMAG0170.jpg not found
Attachment IMAG0183.jpg not found
Attachment IMAG0185.jpg not found
Attachment IMAG0187.jpg not found
1981 KZ750E KERKER
  • 2ndgenKZ
  • 750 LTD
Re: 83 KZ750 LTD
01 Jul 2013 22:28
#594651
Attachment IMAG0206_2013-07-01.jpg not found
When Kerker was fitted. Had to call Kerker (owned by Supertrapp) to get exhaust holders, then trimmed them down. Trying to find those pictures. Made an aluminum bracket to hang it.
Went to MAC 4-1, cant wait to hear it running on all four.
1981 KZ750E KERKER
  • 2ndgenKZ
  • 750 LTD
Re: 83 KZ750 LTD
01 Jul 2013 22:34 - 01 Jul 2013 22:39
#594652
Trying to get a video up.
1981 KZ750E KERKER
Last edit: 01 Jul 2013 22:39 by 2ndgenKZ.
  • 2ndgenKZ
  • 750 LTD
Re: 83 KZ750 LTD
02 Jul 2013 22:15
#594786
She's finally back on all four cylinders. Went through carbs, rebuild petcock back the right way (had the retainer washer on the wrong side of lever), and replaced spark plugs with a better NGK. Compression test was showing 60-60-54-60 on the first hit, couldn't get compression tester to allow for the greater pressures. Going to go through motor this winter, if we have one this year in Georgia. So yeah, feels good to make it run again. Replacing brake master cylinder window tonight, then going on a run tomorrow evening. Try to get video up with the MAC on.
1981 KZ750E KERKER
