1982 KZ1000 CSR
  • zelrok
  • zelrok's Avatar Topic Author
1982 KZ1000 CSR
20 May 2013 11:52 - 20 May 2013 11:58
#588333
Hello all! I figured I'd start a project thread so I could share some pics and get some advice :P
First, the bike as is:
My first task is getting a new tank. I don't have the savvy to repair. Might not even be possible. I'm pretty sure inside is rusted out thanks to a gas cap that doesn't close. There are at least 2 holes that leak gas on the seams.
I found this tank , but its for an LTD and I have a CSR and I'm not sure how different the models are. Looks like it would fit, but I'd rather get some confirmation before spending that cash.
Thanks for reading,
Z
p.s. my flickr album with some more pics
1980 Honda CM400T (sold)
1986 Honda VF700C (Stolen and smashed into tree)
1982 KZ1000 CSR (Current)
Last edit: 20 May 2013 11:58 by zelrok.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: 1982 KZ1000 CSR
20 May 2013 16:42 - 20 May 2013 16:42
#588385
i believe that tank will slot right on.
hopefully someone who knows for sure will confirm.
welcome.
Last edit: 20 May 2013 16:42 by 531blackbanshee.
The following user(s) said Thank You: zelrok
  • zelrok
Re: 1982 KZ1000 CSR
21 May 2013 10:22
#588500
What do you think a tank like this is worth?
1982 Kawasaki KZ1000 Police Gas Tank
  • 531blackbanshee
  • Vendor
  • Vendor
Re: 1982 KZ1000 CSR
21 May 2013 10:29
#588503
a good deal would be a $100.00 but he will will prolly get his 3 out of it.
so if you needed one you wouldn't be getting raped paying the $300.00 for it.
depends how much and quick you need it.
  • NakedFun
  • NakedFun's Avatar
Re: 1982 KZ1000 CSR
21 May 2013 10:45
#588506
Just keep your eyes open on the classifieds here, Craigslist, and EBay and you'll find a good deal on a 81+ tank. Also, remember that though you want a great deal on a tank, really your comparing it to the cost to repair your tank which is the other option, an option that will be much more expensive.
There are parts hiding everywhere for these bikes, so keep looking....
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • zelrok
Re: 1982 KZ1000 CSR
21 May 2013 11:35
#588511
Yeah, that's a great point about comparing the cost to the alternative of fixing up my tank.
Also, how much time I want to spend... The weather is great here in Georgia, and I just want to get this baby up and running.
I actually bought that police tank, we haggled for a bit and settled on 175$.
Should be waiting for me when I get back from memorial day mini-vacation. :)
  • KzChop82
  • KzChop82's Avatar
Re: 1982 KZ1000 CSR
22 May 2013 13:43
#588749
Great engine on that 82 csr- I have it in my chopper.
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
  • zelrok
Re: 1982 KZ1000 CSR
30 May 2013 13:32 - 30 May 2013 13:33
#589932
New tank success. I swapped over the gas cap (after cleansing it and unseizing the lock) and the petcock. The fuel sensor part (I guess that's what it is.) came with the new tank, but the connector isn't what is on my bike. Maybe a difference between the police version and my csr? They are both '82 KZ1000 tanks.
I shooped the panels to black and white to go with the tank. And I don't know what to do about the headlight, seeing as the stock headlight is inside the vetter.
Last edit: 30 May 2013 13:33 by zelrok.
  • martin_csr
  • martin_csr's Avatar
Re: 1982 KZ1000 CSR
30 May 2013 16:55
#589958
Headlight. You could get the needed parts on ebbaayy. The 82 headlight bracket is different & has more chrome than the 81, but I think they are interchangeable. A number of bikes use the same brackets. The 82 kinda mimics the earlier KZ headlight ears. Alternatively, you could get aftermarket headlight brackets, but the stock setup might provide better alignment & adjustment for the headlight beam.
  • zelrok
Re: 1982 KZ1000 CSR
30 May 2013 18:09
#589968
Ebay headlight parts... I'll keep an eye out. I'm a little out of commission because I had to cancel my card. Somebody decided they'd treat themselves to $100 worth of stamps on my dime.
Also,
what sorcery do you use to remove the fuel level sensor?
  • 531blackbanshee
  • Vendor
  • Vendor
Re: 1982 KZ1000 CSR
31 May 2013 10:11 - 31 May 2013 10:19
#590080
pull the rubber cap off and there should be a row of screws around the edge holding it in.
here is a link to a parts diagram showing what your working with.
www.ronayers.com/Fiche/TypeID/26/Type/Fu...9286/Group/Fuel_Tank
Last edit: 31 May 2013 10:19 by 531blackbanshee.
