Kz750 drag bobber build... need motor help
- chopshop
06 May 2013 02:04
Hey guys this is my bobber im building. it has 2006 gsxr 750 forks, nitrous, and clip-ons, and hayabusa rear brake. I am trying to build a n/a high compression motor and want to know any ideas for a good build for a high compression motor with nitrous and dual carb setup.
Re: Kz750 drag bobber build... need motor help
06 May 2013 11:20 - 06 May 2013 11:22
kzzone.com/pistons.html
KAWASAKI KZ, GPZ750 1980 - 1985
DISPLACEMENT BORE SIZE COMP RATIO PART# MFG CODE REQUIREMENTS PRICE
810cc 2.717"
69MM (3MM over) 10.25:1 K810 Cylinder boring only. Includes head gasket 564.44
seems to be a popular kit to pump up the 650/750's .
you should give them a call and talk to them about cam/carb selection.
hth,
810cc 2.717"
hth,
Last edit: 06 May 2013 11:22 by 531blackbanshee.
- chopshop
07 May 2013 03:21
thanks! ive ran across those before but I was really looking to run closer to a 12.5 compression ratio
