My 2000 KZP project bike! First timer, but all out
  • tucsonKZ1kP
  • tucsonKZ1kP's Avatar Topic Author
Re: My 2000 KZP project bike! First timer, but all out
12 May 2013 15:26
#587040
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
12 May 2013 17:08
#587049
Looks great. Are those J engines rubber mounted? Never knew that.
The Kaw List:
  • tucsonKZ1kP
12 May 2013 22:02
#587084
Yep, rubber mounts.
  • tucsonKZ1kP
28 May 2013 12:49
#589582
Here's a little updated photo... We are in process of mounting rear shock now... I am not too confident about the clearance with the 190 tire but we'll deal with that when it comes time.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
28 May 2013 17:18
#589607
lookin good!
  • richard_oxon
  • richard_oxon's Avatar
28 May 2013 18:25
#589610
just a thought , if you moved the trim part you made for the top triple to the bottom , you would gain some ground clearance. alot of the upside down forks seem a bit shorter in length then the standard forks .
** KZ1000 B3 1979 ** 1015cc wiseco pistons 33 smoothbores ported head 410 cams
** KZ1000 A1 1977** 1075 wiseco pistons 438 megacycle cams ported head rs34 flat slides
  • tucsonKZ1kP
01 Jun 2013 12:01
#590271
richard_oxon wrote: just a thought , if you moved the trim part you made for the top triple to the bottom , you would gain some ground clearance. alot of the upside down forks seem a bit shorter in length then the standard forks .
the trim part is covering the nuts on the shaft... it cannot be moved and we also have more than enough clearance.
  • Hollywoodmx
  • Hollywoodmx's Avatar
01 Jun 2013 14:52
#590298
Keep it up man. It looks really clean so far!
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
  • tucsonKZ1kP
02 Jun 2013 12:43
#590438
  • 531blackbanshee
  • Vendor
  • Vendor
03 Jun 2013 10:14
#590630
love that stance . :evil:
keep us posted,
  • tucsonKZ1kP
03 Jun 2013 13:22
#590655
THANKS DUDE!!! I will definitely keep y'all posted.
  • tucsonKZ1kP
09 Jun 2013 13:46
#591452
Little update. Lower and upper shock mounts for the GSXR1000 Shock.
