82 KZ750 Resto / Cafe *updated*
  • Jrbrownie00
  • Jrbrownie00's Avatar Topic Author
Re: 82 KZ750 Resto / Cafe - First Timer
09 Jun 2013 23:30
#591530
Fired up first time every time with the starter clutch rebuild. So happy/relieved that's out if the way. Switched to pods and pulled the air box, bike ran great with no jetting though it doesn't pull in the high end.
How does everyone feel about drilling out the vacuum slides? I'm skeptical.
82' kz750 ltd.
  • Jrbrownie00
16 Aug 2013 22:54 - 21 Aug 2013 09:48
#601771
Added my seat foam which still needs to be trimmed down a bit.
Made my taillight bracket and took it for a spin. Moderate comfort, still feel the big bumps pretty good but it looks killer. 8)
Ordered Uni Pods to replace these cheap EMGO's which hopefully makes a difference like everyone says they will. Also decided to paint the tank but I'll leave that as a surprise.
82' kz750 ltd.
Last edit: 21 Aug 2013 09:48 by Jrbrownie00.
  • Jrbrownie00
20 May 2014 18:20
#633173
Ok so it looks like i neglected this post for a while but here's what i've been up too. I couldn't stand the rust and faded frame paint. The engine was clean but tarnished.
Refinished the wheels
Redid the header/exhaust, painted the swing arm
Rebuilt the forks, Progressive brand fork springs and paint.
Painted the engine and triple tree.
Reassembly begins. New Progressive rear shocks mounted and battery tray cleaned up big time. Don't mind that rusty screw, it's gone now.
Here's how it sat after the winter, seat was temporary but it looked great,
With seat done
With new muffler
Complete list of modifications.
Superbike Bars / Oury Grips
Rebuilt forks with new Progressive fork springs, lowered internally 2-3"
Progressive Rear Shocks
Front Master Cylinder from a 96 ZX7
Ballistics 8cell Lithium Ion Battery
New Carb Holder, UNI Pod filter / Crank case Breather
Shinko 712 Front and Rear tire
RK 530 Chain, New Front and Rear Sprocket
Dyna Solid Core Spark Plug Wires/ New plugs
Dynojet Stage 3 Jet Kit
Detab/Smooth the frame, rear hoop, fresh paint on everything.
Cleaned or Replaced Front wheel bearing
Smaller blinkers from Dime City Cycles
Modified MAC 4-1 Exhaust
MOSFET Regulator/Rectifier from a 2008 CBR600RR
SS Bolt kit from Z1
Rebuilt Petcock
Rebuilt Starter clutch
82' kz750 ltd.
  • rmx1252001
  • rmx1252001's Avatar
20 May 2014 19:05
#633185
Wow... that turned out great! Nice job!
  • Jrbrownie00
21 May 2014 07:54
#633253
rmx1252001 wrote: Wow... that turned out great! Nice job!
Thanks, i'm just trying to work out a timing advancer problem now. My unit seems to be seized.
82' kz750 ltd.
  • Jrbrownie00
22 May 2014 10:49
#633448
Got the timing advancer moving again. From years of neglect and no gasket on that side cover it had seized. It should finally feel like a 750 now.
82' kz750 ltd.
  • Jrbrownie00
11 Aug 2014 16:38 - 11 Aug 2014 18:58
#643520
82' kz750 ltd.
Last edit: 11 Aug 2014 18:58 by Jrbrownie00.
  • willburrrr2003
  • willburrrr2003's Avatar
12 Aug 2014 09:22
#643621
Jr, I'm new hear but have to say you have done a great job on your bike! Thanks for sharing :) What did you use for the paint for the engine and exhaust? Mine is looking at getting some paint here in next couple weeks, but I don't know what will last on the road well, so looking for advice and options.
Regards,
Will
Regards,
Will R.
  • Jrbrownie00
12 Aug 2014 11:27
#643645
willburrrr2003 wrote: Jr, I'm new hear but have to say you have done a great job on your bike! Thanks for sharing :) What did you use for the paint for the engine and exhaust? Mine is looking at getting some paint here in next couple weeks, but I don't know what will last on the road well, so looking for advice and options.
Regards,
Will
Hi Will. Thanks for the kind words. I used vht high temp but i've heard rustoleom grill paint works better especially if you cure it with a heat gun. Id probably try that next.
So I've still been trying to perfect this thing. Refurbished the tank badges was one step, to put on the freshly painted tank!
Attachment ImageUploadedByTapatalk1407867831.321433.jpg not found
Attachment ImageUploadedByTapatalk1407867843.604392.jpg not found
Attachment ImageUploadedByTapatalk1407867859.355963.jpg not found
Added the following
Fork gaiters
Headlight vinyl
Bar end mirror
Lowering spacers for the front end 1.25"
Bright white gloss tank
Attachment ImageUploadedByTapatalk1407867944.346300.jpg not found
Attachment ImageUploadedByTapatalk1407867958.747659.jpg not found
Attachment ImageUploadedByTapatalk1407867972.348769.jpg not found
Attachment ImageUploadedByTapatalk1407867983.016589.jpg not found
Attachment ImageUploadedByTapatalk1407867997.567549.jpg not found
And a pic of my buddies 76 kz400
Attachment ImageUploadedByTapatalk1407868026.586748.jpg not found
82' kz750 ltd.
  • globalsunset
  • globalsunset's Avatar
20 Aug 2014 13:10
#644621
This thing is awesome! I love the most recent incarnation.. the white tank really sets it off and gotta love a meaty rear tire..
1983 Kawasaki GPZ750
2001 Ducati 748
