1974 900 z1 A south Atlanta
- Charles Nix
- 1981 kz 1000c4
03 Feb 2013 23:57
Picked up a early 900 cheap,less than $200 ,it was rode hard and put up wet .It was also knocked over ,under a car port. All the electrics work ,has an old school air brush job,shock lowering brackets,bent drag bars,velosity stacks,Dyna 3 and flat tires. It spins by start button,has numerous dings, bent left rear shock ,some cracked fins ,and a busted carb mounting bracket.The bike was sold to a man in 1995 and it was rode for 5 years.I need some frame measurements or a good frame jig.
- wireman
Re: 1974 900 z1 A south Atlanta
04 Feb 2013 00:05 - 04 Feb 2013 00:09
Wanna double your money?
Hell Ill give ya $500 for it!
Last edit: 04 Feb 2013 00:09 by wireman.
- Charles Nix
- 1981 kz 1000c4
04 Feb 2013 00:10
More pics, It was bought in larenceville Ga.? Some where near Rockdale or River dale,at a kawasaki dealership. The last owner said it would do 140 on the speedo.
- Kidkawie
- I bleed premix
04 Feb 2013 11:22 - 04 Feb 2013 11:22
Nice project. What are your plans for it? I have a database with frame and engine numbers if you want to know if the engine is original to the bike. Here's my current project as I bought it ($350), mainly cosmetic stuff, luckily no broken fins and I got it running after a carb rebuild. Right now the frame has been refinished and the engine is just about ready to be installed.
i114.photobucket.com/albums/n248/Jeekinz...Project/IMG_4811.jpg
My build thread. www.kawasaki-z-classik.com/forum/viewtopic.php?f=18&t=428
There's lots of info on that site.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 04 Feb 2013 11:22 by Kidkawie.
- Charles Nix
- 1981 kz 1000c4
04 Feb 2013 23:08
I will rebuild, I am worried the frame may be bent ,It was bounced around hard .It has damage on both sides. The last owner was a drinker. Under the fuel tank on the right rear frame tube, there is a hard frame hit. I hope to crank it, check it over then dissasemble, and check frame aglinement . Some more pics look close.
- Charles Nix
- 1981 kz 1000c4
04 Feb 2013 23:18Attachment 102_1285.JPG not found
Attachment 102_1294.JPG not found
[attachment:4]C:\fakepath\102_1299.JPG[/attachment]
[attachment:5]C:\fakepath\102_1302.JPG[/attachment]
[attachment:6]C:\fakepath\102_1307.JPG[/attachment]
[attachment:7]C:\fakepath\102_1312.JPG[/attachment]
- Charles Nix
- 1981 kz 1000c4
04 Feb 2013 23:22Attachment 102_1285_2013-02-04.JPG not found
Attachment 102_1294_2013-02-04.JPG not found
Attachment 102_1298.JPG not found
Attachment 102_1299.JPG not found
Attachment 102_1302.JPG not found
- Charles Nix
- 1981 kz 1000c4
04 Feb 2013 23:22[attachment:2]C:\fakepath\102_1294.JPG[/attachment]
[attachment:3]C:\fakepath\102_1298.JPG[/attachment]
- Charles Nix
- 1981 kz 1000c4
04 Feb 2013 23:23
[attachment:1]C:\fakepath\102_1285.JPG[/attachment]
- Charles Nix
- 1981 kz 1000c4
16 Feb 2013 17:09
Got the bikes striped down today .Found a crack in the stator cover of the 74 900 ,also found stripped threads where the clutch cable enters side cover. Rubbed the frame down with marvel mystery,and sanded and painted rear wheel. Hope the pictures work.
- Zedone
17 Feb 2013 19:34
:blink: Wow! I've never seen a set of carbs broke like that before.... or a rear shock! Man that's going to take a wackload of time & $ to get back on the road. I admire your courage.
Cheers, Doug
Cheers, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
