My new project
  • Roadflyer
  • Roadflyer's Avatar Topic Author
My new project
16 Jan 2013 21:09
#567739
Attachment 001_2013-01-16.JPG not found
Attachment quad002.JPG not found
I intercepted my buddy when he was on the way to the dump with this Quad. Its a 1987 Kawasaki Bayou 300. I know I should have just let him go with it, but I needed something to get me through the rest of winter now that the KZ is done. I'm not even going to try and make it pretty, just get it running well and give it to my daughter to use on her farm.
The KZ is completed and tucked away for spring, it now has a new seat, I just can't take any pictures where it is now.
1979 kz1000 shaftie rebuild project
1045 wiseco 10.25-1 pistons
Kenny Harmon 380 lift cams
  • gengomerpyle
  • gengomerpyle's Avatar
Re: My new project
16 Jan 2013 21:26
#567748
the kz looks great
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • Marklorenzo
  • Marklorenzo's Avatar
Re: My new project
20 Jan 2013 01:11
#568255
Looks like a fun project!
1984 KZ700 A1
  • Roadflyer
Re: My new project
20 Jan 2013 12:03
#568289
Marklorenzo wrote: Looks like a fun project!
The quad should run today, new +1 oversize piston, rings and valves. The dirt on this thing is baked on, the only way I've found to get it off is to sand it.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: My new project
21 Jan 2013 11:45
#568495
do you know anybody with a steam cleaner?
like for cleaning heavy equipment,farm equipment.
once it is all cooked on it seems like some high heat is the only thing that will soften it up again.
  • Roadflyer
Re: My new project
22 Jan 2013 17:36
#568686
531blackbanshee wrote: do you know anybody with a steam cleaner?
I soaked it down with Simple Green and hit it with my 5 hp pressure washer with hot water infeed.
It took all the oily stuff off and loose dirt, it looked good 'till it dried. Its too cold here to use my sandblaster outside. I guess i'll just keep going with the sandpaper and brush a coat of Tremclad on the frame.
I got the motor back together with new piston and valves, but the ignition box is NG now. I have a new one from Rick's on the way but will have to adapt the harness for it to plug in.
  • 531blackbanshee
  • Vendor
  • Vendor
Re: My new project
22 Jan 2013 22:56
#568742
maybe a wire wheel on a grinder or drill might be a lil quicker than sanding.
  • Roadflyer
Re: My new project
23 Jan 2013 02:45
#568773
531blackbanshee wrote: maybe a wire wheel on a grinder or drill might be a lil quicker than sanding.
Good idea!
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: My new project
23 Jan 2013 09:32
#568802
I feel your pain Roadflyer, my resto had the same issue. It was originally from Alaska and they must have lived on a dirt road. On the engine it had a combination of baked dirt wit oil. I called it baked Alaska. Only way it would come off was with a wire wheel (most of the time) or having to use a metal scrapper. Many, many hours over the months before I got all. A sand blaster would have spared me all that.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: My new project
23 Jan 2013 19:29
#568851
The shaftie looks great ! Mine probably not look that good. Mine will be blue.
Good luck on the quad. Roy
  • Roadflyer
Re: My new project
23 Jan 2013 22:32
#568877
Baked Alaska- Too funny! I like that! It pretty much describes this stuff.
  • Roadflyer
Re: My new project
23 Jan 2013 22:38
#568880
roy-b-boy-b wrote: The shaftie looks great ! Mine probably not look that good. Mine will be blue.
Thanks Roy, Blue will look great on that bike. I ordered my paint online and it looks NOTHING like what was on the color chart. That's OK, its grown on me and I like it a lot now. The only reason its not Blue or Red like the Ducatti is that I'm too cheap to throw away a $50 quart of paint when it shows up wrong!
