the new project :D
- stunter956
the new project :D
11 Jan 2013 14:52
so i got the black 82 kz550 for 20 bucks from a friend, he only used it for parts on his bike, the blue one 79 kz550 i got off a guy on craigslist, wich is gonna be used as the donor bike for the black one, so far i got the blue one to start wich is good since the motor will be swaped. im gonna go simple on the build, lowered and maybe stretched once i figure out how to do that, gonna be a great build
Attachment 537375_499130046805225_2134288466_n.jpg not found
1976 kz900 "mean green"
- guitargeek
Re: the new project :D
11 Jan 2013 16:55 - 11 Jan 2013 16:56Why?? These bikes handle pretty good, it's one of their strengths, why not build on that?stunter956 wrote: lowered and maybe stretched
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Last edit: 11 Jan 2013 16:56 by guitargeek.
- loudhvx
11 Jan 2013 18:26
That black one looks to be a 1981 KZ550D1 Gpz. Use those pistons and head along with the oil cooler if you can. It will be more of a screamer.
The blue one looks to be a 80/81/82 KZ550A. That motor has less zing, but can pull stumps all day long. If you are going for wheelies, the blue bike's motor with airbox would probably be a better motor. If you can get the brakes working on the black one, they will stop better than the blue bike.
There is a ton of kz550 info in my signature including several manuals which you should grab.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- stunter956
12 Jan 2013 13:23
thanx loudhvx, i will check them out and thanx for the motor info i will stick with the blue one cus i am looking into wheelies plus the black one is missing pieces on the motor and i really just want to swap and go,
Guitargeek, well i havent started just yet on the building, ur right, i might just keep her stock, but will see once making sure shes running correctly.
- Kitten Tooth
12 Jan 2013 20:30
Awesome
cant wait for this one. Good score for 20 bucks on the GPZ. thats nice. You'll have plenty of parts left over to get 3 times that ammount on Ebay when your all done.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Stickybrains
23 Jan 2013 19:57
I found the original facotry service manuals for that kz400 kz500 kz550
I just finished a full rebuild of my 81 kz550
She will do wheelies off throttle the "peppy" gearing. great in the twisties. like a lighter version of kz650.
docs.google.com/file/d/0B0LxNUBYfNL8MXU2T0Q1R01IX0k/edit
There are ERRRORs in some of the other service manuals i found. Mainly in the CAM timing carburetor and valve sections with discrepancies. DOUBLE CHECK YOUR CAM TIMING AGAINST MULTIPLE MANUALS! and READ THIS!!! DONT USE ANYTHING EXCEPT THE FACTORY SERVICE MANUAL link above or buy the real deal.
home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
voila
- loudhvx
23 Jan 2013 22:16home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.htmlStickybrains wrote: home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
1981 KZ550 D1 gpz.
Other links.
Other links.
