cool little father son type project....
- lushbaugh
- everybodys a pro......
03 Dec 2012 00:03
counter sprocket belt buckle....
first you will need a few things like
> obviously a worn sprocket
> a couple small nuts , i used eight millimeters.
> wire for belt loop, i used an old door lock linkage.
> an eight millimeter head long bolt, i used a long one so
i could use the thread-less portion.
tools:
> mig welder
> 90 degree grinder
> cookie wheels, 36 grit and scotch brite wheel.
> vise grips
> cut off wheel
note: you can use whatever you have as theres many ways to accomplish the same thing.
tools:
> mig welder
> 90 degree grinder
> vise grips
> cut off wheel
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- lushbaugh
Re: cool little father son type project....
03 Dec 2012 00:05
step one clean up sprocket front and back using grinder and cookie wheels, rough the smoothing with scotch bright pad.....
- lushbaugh
03 Dec 2012 00:09
step two clean up small nuts for a clean weld. use vise grips to hold it as the cookie wheel will rip it out of your hands and dont over kill the visegrips it will crush the nuts.
then mount the nuts in place using clamps, you can see i used a scratch awl to position them you can use what youd like or eyeball it.
- lushbaugh
03 Dec 2012 00:17
step four weld the nuts in place. a tack weld will do but that aint my style...
step six you are going to shorten the long bolt for the belt catch and clamp it in place for welding...
- lushbaugh
03 Dec 2012 00:19
- lushbaugh
03 Dec 2012 00:23
next your gonna bend the belt catch so it stays in place, clamp it down, i used a vice with
a rag to protect the finish then i vice gripped the end, applied a lil heat and bent. after bending i shortened the prong a bit and removed any sharp edges.
- lushbaugh
03 Dec 2012 00:27
next your gonna bend and cut your wire to make your loop
me emulating the loop shape befor installing...
- lushbaugh
03 Dec 2012 00:33
install into nuts and crimp prongs in, you will see i bent up the ends like a cotter pin to strengthen the loop and then you should look like this...
now i loved the raw metal look so i decided to clear coat it to protect it.... also i may epoxy some empyt shell casings in the lightening holes later. enjoy and wear safty gear so the kids learn correctly
- Nebr_Rex
03 Dec 2012 00:33
Now you know some asshat in Texas is going to have make one out of a rear sprocket.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- lushbaugh
03 Dec 2012 00:38
hahaha everythings bigger in texas
- mark1122
- Keep twisting it
03 Dec 2012 11:53
What a great father son project.
Thanks for sharing.
Thanks for sharing.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- wireman
03 Dec 2012 13:53:laugh: :laugh: :laugh: :laugh: :laugh:Nebr_Rex wrote: Now you know some asshat in Texas is going to have make one out of a rear sprocket.
