Rabies 77 kz750B in a blender with 06 R1
- rabies
- holla
19 Nov 2012 16:31
well, i finally went and picked up the bike.
tonight im ripping it apart. lots of stuff to throw away.
maybe pick up an R1 front end also..if the price is right
picture sharing
well....here we go..
i started off with a fork swap
snap ring
kz stem too small. ended up using the r1 stem
picture sharing
snap ring
"boy its hot out.....oh..my bike is on fire"
- rabies
- holla
Re: Rabies 77 kz750B in a blender with 06 R1
19 Nov 2012 16:31
- rabies
- holla
19 Nov 2012 16:32one plug was corroded, one was oily
airbox? junk
mastercylnder jus fell apart when unbolted
how far is this clutch rod thingy supposed to move in?
ready for it...?
- rabies
- holla
19 Nov 2012 16:32
- rabies
- holla
19 Nov 2012 16:33
- bluezbike
19 Nov 2012 16:49
Lookin' good, you sure don't hang about with the chop saw!!
79 KZ 1000 LTD
- badrhino
20 Nov 2012 21:25
Looking good. That's what I wanna do with mine some day is swap out the suspension for newer stuff. Call me crazy but for some reason that bright orange and Yamaha blue looks good together. :woohoo:
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- rabies
- holla
26 Nov 2012 12:33
rtv glue for diaphram ??
ninja 250 swingarm
bolt would not budge, hammer, impact etc. was seized in there.
segway lol
fyi there is no hub on the ninja wheel yet
got rearsets on. made spacers and used 1 existing hole on each side.and drilled 1 hole on each side.
had to weld on nuts to back these out
ninja 250 swingarm
segway lol
- rabies
- holla
26 Nov 2012 12:34
had to make spacers for the bones
used ex250 ninja bones. ex500 ninja unitrack and shock.
is this geomtry goin to be ok? sitn on it and has spring rebound like normal
booya. ex250 ninja swingarm and monoshock conversion
- rabies
- holla
27 Nov 2012 09:51
- rabies
- holla
27 Nov 2012 09:51
my attempt to shave weight. nor could i find extended lines for both sides.
like everyone told me. after the brake was bled the master cylnder was too stiff for one side. less fluid?
ghetto tool
the wheel looks pretty stupid without the rotor on there.
resevoir delete
new carb gaskets
ghetto tool
resevoir delete
new carb gaskets
