HART SYSTEM Kaw Projects
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: HART SYSTEM Kaw Projects
23 Nov 2012 12:57 - 23 Nov 2012 12:58
#559744
the thing about having les build you an arm or rslingshot or me mod one when either of us get done.
it is a bolt in deal :evil: .
no worries there.
Last edit: 23 Nov 2012 12:58 by 531blackbanshee.
  • K.D. HART
  • K.D. HART's Avatar Topic Author
06 Dec 2012 00:18 - 06 Dec 2012 00:36
#561580
I started to do some work on the 74. It sat outside for 23 years.
So I scrubed, pressure washed it again, sprayed it down with WD-40 and brought it from the shed to my garage.
I then had some keys made, bought a battery, new plugs, cleaned the tank, changed the oil, removed the front brake pads, so I can move the damn thing, removed the carbs to be rebuilt and took them to a bike mechanic I know personaly.
I'm getting closer to firing this old girl up. Someone robbed the points and points cover long ago. I've been thinking of installing a Dyna S in it, but need to do some more research first. I just want a trouble free runner, not something I need to program.
I've run power through the bike, but the starter won't kick in. I see the speedo lights flicker a little when I push the starter button, so I know something is drawing juice. I ran a jumper to the starter and it works. I think maybe the solenoid is bad?
Last edit: 06 Dec 2012 00:36 by K.D. HART.
  • kzz1king
  • kzz1king's Avatar
06 Dec 2012 00:53
#561588
The Dyna is a good ignition. Many of us use them.My 74 looked like that once. I like that color.
Wayne
Home built KZ1000 turbo setup
