- Thank you received: 16
les holt wrote: Not sure on the wheels of the 10 and 6 being different but I would bet that the 10's are wider. The 14's are heavy compared to the others by quite a bit. On the forks, Suzuki's are pretty consistent on fork size and length but Kaw's are all over the place. I like the newer stuff myself but they don't lend themselves to gullwinged trees well, you have to drop the lower tree as well. The way I see it is get a whole front to match the wheel your wanting. It saves on parts selection and debugging although I put 04 wheels on my bike that has 09 forks and an arm with spacers built to take an 09 wheel and rotor spacing was dead on, had to make spacers for the front wheel but that isn't uncommon. The rear was a dead bolt in. The only real suggestion I have is to buy a complete later model setup forks with the brakes, master cylinder and axle. I know the money is higher but, you get parts that aren't wore out, parts that match and most of the time you save money over the total package. I just worked a deal on new zx14 forks with calipers and master for fair money so they are out there, just use a plan and follow it, it will save you tons of money in the long haul.
Les
Drooz wrote: Hey, nice Project!! I'll be following along with interest!
I believe the zx6r rear wheel is 1/2" narrower than the zx10r. At least, the '04 -'05 one's are. It made it a little easier to get the chain inside the frame and past the wheel/tire. You can still use a 180mm tire.
We used a zx6r rear wheel and a whole zx10r front end on my KZ.
Zedone wrote: Can you post more pics of your swingarm? I've never seen a Calfab with that type of extruded alum. tubing before... maybe it's a one off?
Sweet. How did you know how to delete the relays? When I did this one the TR-1 I used the wiring diagram with a forum post of instructions, more or less.
The swingarm on the supercharged bike just looks like a stock arm with an extra tube brace welded underneath and then painted silver.
Later, Doug
Ok good to know. Do you have pics of your bike in thread somewhere?
Zedone wrote: Nice bike Hollywood!
Very innovative head work.
You might want to install some SS braided brake lines, and it appears that your rear rotor has a decent size groove worn into it... I'm wondering how your brake pads are also. The stock Z1 KZ brakes are OK at best... let alone having a blower thrown into the equation :laugh: . A set of super bike bars or clip-ons would really inspire confidence also.
Someone spent alot of time and resources into your bike... I like the direction your headed with a super bike / cafe influence.
It almost looks like your pipe has been ceramic coated (hard to tell from a pic though). The new oil coolers available are much larger and make a noticeable improvement over the older ones.
Regards, Doug
Later, Doug
531blackbanshee wrote: a custom fabbed aluminum belt cover with holes and lexan over each pulley would be cool.
You only need a relay if you are switching a current that is more than the switch gear can handle
e.g starter motor, twin headlights etc.
As for the choice of wheels discussion the widest a std Zed frame will take whilst keeping the wheel true central is a 5.5 inch rim e.g, zx636,Z750,zx7r,zx9 etc .
With a 5/8 offset sprocket the measurement from swingarm spindle center (chassis/wheel center line) to the inside face of the sprocket is 101mm which usually equates to approx 8mm off the rear wheels sprocket carrier to align the chain.
A zx10r rear is 6 inch and won't fit unless it's offset which i think is bad practice.
If you want better/quicker handling rather than pose value go for a 170 rear tyre.
The ideal set up is 5/8 offset front with 19teeth, 530 pitch to get max clearance between the chain,frame and swingarm.
The original zeds final gearing is 2.2 to 1.
To compensate for the smaller 17" rim use 1.92 to 1 for the closest equivalent.
Sure, I've got a few pics.
There are a few others if you need some detail, but that's pretty well it. I also run a 5/8" offset sprocket (see pic) and an idler wheel to keep the chain off the swingarm bottom brace. There is a mylar strip on the top of the swingarm (see pic), and it's needed!!
Hope that helps some.
Hollywoodmx wrote:
Zedone wrote: What swing arm is that, gsxr?
JMC, England.
Nice swing arm. Difficult folks to deal with. :blink:
