Lots of ???'s and no skills......
  • ODFan
  • ODFan's Avatar Topic Author
23 Oct 2012 22:26
#555473
Ok guys, let me up front and honest from the beginning. I have little to NO mechanical, electrical or body skills. I'm not a fabber or welder, so my skills are very limited. With that being said, I'm very eager to learn and make this old kaw my own. I'm going to start the only way that I know how and that's to ask a lot of questions, and then adjust my progress from there. So, here goes and thanks in advance for your help and patience.
77 KZ1000P
First three pics are three of the pieces in the process of sanding. What is the writing on the pieces you ask? Someones failed attempt at airbrushing the decals on and clear-coating over.
1. Pics #4-#6:
Swingarm appears to be extended, is this stock or aftermarket?
Can anyone tell how far it's been extended?
Are these the stock wheels?
2. Pics #7 & #8:
Isn't the rear brake supposed to be over the exhaust?
It appears as if someone has welded some metal to the original brake to make it fit under the exhaust?
Are the pipes & slip-on a match? Or is that the issue with the brake?
Attachment IMG_1184.JPG not found
Attachment IMG_1185.JPG not found
Attachment IMG_1186.JPG not found
Attachment IMG_1187.JPG not found
Attachment IMG_1188.JPG not found
Attachment IMG_1189.JPG not found
Attachment IMG_1191.JPG not found
Attachment IMG_1192.JPG not found
After 10 years of wanting, I finally have a KZ1000!!
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Lots of ???'s and no skills......
23 Oct 2012 22:35 - 23 Oct 2012 22:45
#555478
welcome to KZR....we will help if you ask.
One...swingarm is factory....19-20" is stock....chrome is not.
two....stock wheels 16" rear 19" front.
three....sidewinder header....you have to modify the brake pedal on a kz. See how I did mine below. I bent it way to far...LOL
Attachment bike053.JPG not found
Last edit: 23 Oct 2012 22:45 by 4TheKZ1000.
  • ODFan
23 Oct 2012 22:36
#555479
3. Pic #9:
Any clue what type of bar this is?
4. Pic #10
Bike had risers on it and I'm slowly cleaning up the electrical mess. :angry:
  • 4TheKZ1000
23 Oct 2012 22:43 - 23 Oct 2012 22:51
#555481
the bars just look like a stright bar.....nothing special.
my wiring was screwed up also.....there are replacement harness if you get pissed and say f..it like I did...LOL about $160 If its a police....lots of extra wires I would think.....could be a prob for a novice.
Get a correct manual for your bike and read it front to back 100 times....like I did.
Last edit: 23 Oct 2012 22:51 by 4TheKZ1000.
  • ODFan
23 Oct 2012 22:52
#555487
Ok, so because my swingarm isn't factory because it's chrome? What location do I measure from to see length?
Can't I just mount pegs in a different location and move brake back over exhaust?
  • 4TheKZ1000
23 Oct 2012 22:56 - 23 Oct 2012 22:57
#555489
ODFan wrote: Ok, so because my swingarm isn't factory because it's chrome? What location do I measure from to see length?
I think its factory....someone just had it chromed......could be chromed at factory for a police...someone will let us know...I really dont ever rem seeing a chromed one from factory.????
Are you sure its a 77 I dont see a police model listed till 1978...what is the frame number???
Last edit: 23 Oct 2012 22:57 by 4TheKZ1000.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 Oct 2012 22:58 - 23 Oct 2012 23:01
#555491
the swing arm is stock, but someone had it chromed. to measure the length, u can measure from the pivot axle bolt to the wheel axle bolt.
u can cut the brake peddle off and reweld it on in a preferred position. anything goes when u mod things. just start cutting bending and welding and dont stop until u r satisfied with the results.
oh, and have fun. Chop, Chop.
:P
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 23 Oct 2012 23:01 by mark1122.
  • 4TheKZ1000
23 Oct 2012 22:59 - 23 Oct 2012 23:04
#555492
If you measure from center of swingarm pivot bolt to center of rear mounting flange....should be 19 to 20" if a stock arm....red arrow at bottom will give you number.
Attachment bike021.JPG not found
Last edit: 23 Oct 2012 23:04 by 4TheKZ1000.
  • ODFan
23 Oct 2012 23:01
#555494
Is that the same as the VIN?
  • 4TheKZ1000
23 Oct 2012 23:06
#555496
ODFan wrote: Is that the same as the VIN?
ya its on the neck.....
  • ODFan
23 Oct 2012 23:08
#555498
Neck = KZT00B-504365 Engine = KZT00AE029645
Are they supposed to be different?
  • 4TheKZ1000
23 Oct 2012 23:11 - 24 Oct 2012 09:34
#555500
when you go to paint the plastic....you might want to call my body and paint guy....he had to redo mine do to a primer problem ....he said the primer "rang out"....I would guess it was a shrink problem.....like where you sanded on the tail piece....He also sanded on mine just like yours...after painting it was showing as a slight depression in the paint due to primer shrinking. Would hate for you to have to have done again....let me know if you would like to give him a call....I will pass on his number and let him know your calling.
Last edit: 24 Oct 2012 09:34 by 4TheKZ1000.
