Lots of ???'s and no skills......
- ODFan
77 KZ1000P
First three pics are three of the pieces in the process of sanding. What is the writing on the pieces you ask? Someones failed attempt at airbrushing the decals on and clear-coating over.
1. Pics #4-#6:
Swingarm appears to be extended, is this stock or aftermarket?
Can anyone tell how far it's been extended?
Are these the stock wheels?
2. Pics #7 & #8:
Isn't the rear brake supposed to be over the exhaust?
It appears as if someone has welded some metal to the original brake to make it fit under the exhaust?
Are the pipes & slip-on a match? Or is that the issue with the brake?
Attachment IMG_1184.JPG not found
Attachment IMG_1185.JPG not found
Attachment IMG_1186.JPG not found
Attachment IMG_1187.JPG not found
Attachment IMG_1188.JPG not found
Attachment IMG_1189.JPG not found
Attachment IMG_1191.JPG not found
Attachment IMG_1192.JPG not found
After 10 years of wanting, I finally have a KZ1000!!
- 4TheKZ1000
- Visitor
One...swingarm is factory....19-20" is stock....chrome is not.
two....stock wheels 16" rear 19" front.
three....sidewinder header....you have to modify the brake pedal on a kz. See how I did mine below. I bent it way to far...LOL
Attachment bike053.JPG not found
- ODFan
Any clue what type of bar this is?
4. Pic #10
Bike had risers on it and I'm slowly cleaning up the electrical mess.
- 4TheKZ1000
- Visitor
my wiring was screwed up also.....there are replacement harness if you get pissed and say f..it like I did...LOL about $160 If its a police....lots of extra wires I would think.....could be a prob for a novice.
Get a correct manual for your bike and read it front to back 100 times....like I did.
- ODFan
Can't I just mount pegs in a different location and move brake back over exhaust?
- 4TheKZ1000
- Visitor
ODFan wrote: Ok, so because my swingarm isn't factory because it's chrome? What location do I measure from to see length?
I think its factory....someone just had it chromed......could be chromed at factory for a police...someone will let us know...I really dont ever rem seeing a chromed one from factory.????
Are you sure its a 77 I dont see a police model listed till 1978...what is the frame number???
- mark1122
- Keep twisting it
- Thank you received: 109
u can cut the brake peddle off and reweld it on in a preferred position. anything goes when u mod things. just start cutting bending and welding and dont stop until u r satisfied with the results.
oh, and have fun. Chop, Chop.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 4TheKZ1000
- Visitor
Attachment bike021.JPG not found
- ODFan
- 4TheKZ1000
- Visitor
ODFan wrote: Is that the same as the VIN?
ya its on the neck.....
- ODFan
Are they supposed to be different?
- 4TheKZ1000
- Visitor
