KZ1000 Dymag 5.5" rear wheel fitment.
  • Slashaguc
  • Slashaguc's Avatar Topic Author
20 Oct 2012 06:39
#554824
Hi All,
I have a '79 KZ1000 that I want to fit a set of Dymag Classic H 18" wheels into. The rear wheel is 5.5" wide and will take a 180 section tyre. I plan on using 520 sprockets with a high quality sealed roller chain. Obviously this set up will require an offset sprocket on the engine. The sprocket sizes are 18T front & 41T rear.
However, I am not sure if the chain run will foul the inside of the frame tubes under the bodywork's side cover and I'm wondering if anyone had done this conversion who may be able to advise. If this is the case, I have no problem cutting a section out from each of the tubes and tig-welding in a flat plate to close them up in order to allow the chain a clear run. The reason for my post is just to put it out there so that I know what's involved before I start.
Thanks in advance for your time guys! Slash.
Keep'er pinned, Tina!
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
Re: KZ1000 Dymag 5.5" rear wheel fitment.
20 Oct 2012 08:03
#554829
I'm running 5/8" offset front, 530 drag chain and 180 rear tire, no from rub on mine and wheel is centered, no offset.
Les
  • ramtough_63
  • ramtough_63's Avatar
20 Oct 2012 09:56
#554831
I am running a 5.5 rear wheel with 1/2" offset 520 DID ER2 or 3 chain 190 shinko Tire. chain clears the frame fine widest tire possible will have to releave the sprocket cover slightly because of thr frame offset
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • Harvey1327
  • Harvey1327's Avatar
21 Oct 2012 06:18
#554951
530 chain,5/8 offset sprocket and 5.5 rim and 180 tyre . Only paint missing on inside frame and no chain damage. I've hit 250 kph (155 MPH) at Phillip island and still good.
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
  • Samminorwich
  • Samminorwich's Avatar
18 Jan 2022 17:32
#860730
Hi would you know the std offset for the spoke 18 inch rear I made the stupid mistake of mounting new spokes without measuring no one in the UK can help me I want to ride safe
re Samantha
  • 750 R1
  • 750 R1's Avatar
18 Jan 2022 19:11 - 18 Jan 2022 19:11
#860736
re Samantha
There are tons of capable members of the UK Z1 forum Sam, there is NO offset, the centre of the rim should be over the centre of the hub...
PM member zed1015 , his name is Rob, if he can't help you , no one can....   He's also a member of both forums....
Last edit: 18 Jan 2022 19:11 by 750 R1.
  • Mikaw
  • Mikaw's Avatar
18 Jan 2022 19:23
#860738
re Samantha
These member are talking about offset front counter sprocket. It moves the chain alignment out from the engine cases so the chain will clear a wide tire. Not the information your looking.
