1976 KZ400 Gift
Re: 1976 KZ400 Gift
22 Sep 2012 06:33
#550233
Z1E also carries a variety of handlebars and a large selection of brake hoses.
Handlebars
Brake hoses
Good Fortune! :)
  • pjed
  • pjed's Avatar Topic Author
Re: 1976 KZ400 Gift
17 Oct 2012 21:16
#554403
Got the carbs all cleaned but having trouble finding the O ring for the main jet. The part number is 16038-013 and is no longer available. Tried several from the local hardware store but no luck. Anyone know if this part is interchangeable with other models/part #? Will try couple other stores in town...fingers crossed.
1976 KZ400 D3
2008 Kawasaki Ninja 250 (sold)
2005 Kawasaki ZX6RR (sold)
2013 Harley Davidson 883 Iron
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: 1976 KZ400 Gift
21 Oct 2012 21:59
#555058
McMaster carr is the go-to place for o-rings. They have just about every size imaginable. I went thru this recently for my KZ400D and that is the route I took. When I upgraded to larger mains I just bought them from Power Barn and they already have the orings on the jets.
Kawaski Twin Owners Forum
is a great resource
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • pjed
Re: 1976 KZ400 Gift
24 Oct 2012 00:08
#555516
ThatGPzGuy wrote: McMaster carr is the go-to place for o-rings. They have just about every size imaginable. I went thru this recently for my KZ400D and that is the route I took. When I upgraded to larger mains I just bought them from Power Barn and they already have the orings on the jets.
is a great resource
Thanks for heads up on the forum...looks like another great source of info.
1976 KZ400 D3
  • pjed
Re: 1976 KZ400 Gift
24 Oct 2012 00:13
#555517
Ended up buying a couple rebuilt kits from Japan on eBay. Don't have everything I need but I'll give them a try.
Looking at setting the float height. Is there any other method than connecting a clear tube to the drain? The measurement in the manual refers only to the fuel level in the line but I remember I could set float height on some Honda CB carbs by measuring the distance from the bottom of the float to the carb body.
1976 KZ400 D3
  • pjed
Re: 1976 KZ400 Gift
21 Jul 2013 23:10
#597631
Haven't had time to work on the bike for a while. Finally got back to it and it appears that the coil may be bad. I pulled a plug, connected it to the plug wire and grounded it on the block. No spark when cranked. Checked the resistance on the coil: primary 4.3 and getting nothing on the plug wire. Looking at replacement coils on eBay and they all state 90mm (3.5 inch) center to center mounting. My coil has about 100 mm or close to 4 inches between mounting bolts...is that the right distance for my bike? Could this be a replacement by a PO?
1976 KZ400 D3
  • martin_csr
  • martin_csr's Avatar
Re: 1976 KZ400 Gift
22 Jul 2013 09:39 - 22 Jul 2013 09:39
#597673
You could check the diagrams or look on ebbaayy to see if you can figure out whether or not the coil is stock. Or look at the frame - chances are that nobody modified the coil mounts there.
Z1Enterprises sells an Emgo coil w 90mm center-to-center mounts. Although inexpensive, others say they are good.
Z1Ent - EM24-72451
Last edit: 22 Jul 2013 09:39 by martin_csr.
The following user(s) said Thank You: pjed
  • pjed
Re: 1976 KZ400 Gift
22 Jul 2013 14:11
#597716
Thanks Martin. Went ahead and ordered the one from Z1. I'll chop/weld the bracket to make it fit.
1976 KZ400 D3
  • martin_csr
Re: 1976 KZ400 Gift
22 Jul 2013 15:33
#597727
Did you verified the application? I'm not 100% sure it's correct for the KZ400.
  • pjed
Re: 1976 KZ400 Gift
22 Jul 2013 16:17
#597736
martin_csr wrote: Did you verified the application? I'm not 100% sure it's correct for the KZ400.
Yup...should be good.
1976 KZ400 D3
  • pjed
Re: 1976 KZ400 Gift
31 Jul 2013 21:49
#599324
Got the new coil on but still not running. I pulled the plug, connected it to the wire and set it against the block. Seems I only get spark right when the motor starts turning and when I let off the starter button. Any thoughts?
1976 KZ400 D3
Re: 1976 KZ400 Gift
31 Jul 2013 22:10
#599330
Is your battery fully charged? If not, it may be drawing so much energy to turn the electric starter that there's insufficient power left for the coil. Do not try jump starting the engine from a battery charger or running vehicle. Ed
