Different Pipe Wrap
- time440
25 Aug 2012 12:00 #544687
by time440
1980 KZ440B
Different Pipe Wrap was created by time440
New member here. Thought some might be interested in the slightly different approach I took on wrapping my pipes. I'll get some better pictures in the future, as this was an early attempt and the re-wrap is much cleaner. It's called a harlequin wrap.
Attachment WrapDetail.JPG not found
1980 KZ440B
- wireman
- Thank you received: 299
25 Aug 2012 12:03 #544689
by wireman
Replied by wireman on topic Different Pipe Wrap
Wrapping pipes is supposed to help keep heat in the pipes for a little more power,but at same time it traps moisture rusting out pipes faster
- time440
25 Aug 2012 12:09 #544692
by time440
1980 KZ440B
Replied by time440 on topic Different Pipe Wrap
Yeah, I can't imagine that I'll really notice a power boost from it, but maybe I'll be pleasantly surprised!
As for the pipes rusting out, I've heard that, and tried to take as many precautions as possible. I first thoroughly cleaned the pipes and tried to remove any traces of corrosion. Then I put a couple coats of high-temp paint on the pipes to provide another barrier. Then I wrapped them.
I also plan on using the high-temp silicon paint over the wrap to help seal it further, but that's a project for another day. Hopefully all that work will save me a major headache later? :dry:
1980 KZ440B
- wireman
25 Aug 2012 12:13 #544694
by wireman
I wouldnt paint the wrap itself with anything,that would just trap more moisture in there
- time440
25 Aug 2012 12:23 #544696
by time440
1980 KZ440B
That makes sense to me, though I was going by the manufacturer's directions... I would probably need multiple cans before I'd really believe that I fully sealed it though.
1980 KZ440B
- wireman
25 Aug 2012 12:28 #544700
by wireman
Im guessing theyre suggesting it to protect the wrap itself,not the pipe under it.
Maybe check with somebody who races stock cars or 1 of their websites,I think theyre the ones who really started the craze with wrapping header tubes way back when
