KAW-A-CIDE ....... RELOADED
- 4TheKZ1000
Re: KAW-A-CIDE
15 Aug 2012 08:49 - 08 May 2013 00:37
The front rim is 2.75 x 19 with a 110 x 19 tire.
The rear is a 3.50 x 18 rim with a 150 70 18 tire.
The tach is a Autogauge 5" with shift light. The speedo is a factory Kawasaki with upgraded face.
Attachment not found
Last edit: 08 May 2013 00:37 by 4TheKZ1000.
- kawasaki mike
- kawasaki mike
Re: KAW-A-CIDE
18 Aug 2012 01:22Attachment craigs058.JPG not found
Attachment craigs054.JPG not found
Very good looking bike brother. Love everything about it. I dig the wire rims. Wish you would swap me for my mags. Cant really tell if your rear is a 16 or not.(Mike)
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
- 4TheKZ1000
Re: KAW-A-CIDE
18 Aug 2012 10:20 - 18 Aug 2012 10:22
The rear rim is 3.50 x 18. The tire is 150 x 70 x 18
The front rim is 2.75 x 19. The tire is 110 x 19
I thought about mags. When I researched them, I quickly made the choice to go with wires. I was disappointed with the mag rim sizes. Even though the Z1 rim went to 3.0 x 18 it just wouldn’t fit the 150 to 160 x 18 tire properly.
I wanted to go with a 160 x 18 tire in rear. I settled with a 150 x 18 as it would work with all stock items. I had to do nothing special to run this tire. The spacing is dead stock and used the stock counter shaft sprocket. The chain clears the tire sidewall by a ¼ inch, but doesn’t touch tire.I might do this conversion down the road….ie winter time, but really not serious about it.
If the 160 x 18 would have been chosen, an offset front sprocket and rear sprocket spacer would have to be made / used with some fuss. The rim would have had to go to a 4 x 18 to properly cradle the tire sidewalls.
Thanks for comments and interest.
Last edit: 18 Aug 2012 10:22 by 4TheKZ1000.
- baldy110
Re: KAW-A-CIDE
18 Aug 2012 18:54
Wow that is very nice. Are those RS36 carbs and if so what settings are you running with them.
- BlackZ1R
- Kawasaki in my blood
Re: KAW-A-CIDE
19 Aug 2012 23:11
I'm digging that rear tail light. Who surfaced your front rotors? Is that factory drilled pattern?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- 4TheKZ1000
Re: KAW-A-CIDE
19 Aug 2012 23:18 - 19 Aug 2012 23:18
Stock 1978 Kawasaki 1000 "A" brake rotors on front. Drilled from factory and not messed with...must be the pic throwing you off.
Last edit: 19 Aug 2012 23:18 by 4TheKZ1000.
- sc/ant864
Re: KAW-A-CIDE
19 Aug 2012 23:37
Man that thing is beautiful! The wires look great and good spacing so cleaning wont be a bear, also love the way you turned the rear piggyback shocks around....never seen that done and I like it cause it's different. Great bike, you should make a video...you know pron is better in mpeg format than jpeg. :laugh:
kzrider.com/forum/11-projects/543276-77-...543286]'77KZ900-1000
streetstrip project
'77KZ900/1000
'89BMW E30 325i sedan
'88Mustang GT
'77Datsun PL620 KingCab
George Carlin- "I often think how different the world would be if Hitler had not been turned down when he applied to art school."
'77KZ900/1000
'88Mustang GT
The following user(s) said Thank You: 4TheKZ1000
- BlackZ1R
Re: KAW-A-CIDE
20 Aug 2012 18:244TheKZ1000 wrote: Stock 1978 Kawasaki 1000 "A" brake rotors on front. Drilled from factory and not messed with...must be the pic throwing you off.
Looking good. they look like they have less than 10 miles on them. I still see the surface marks from the surface grinder...
Kawasaki
- 4TheKZ1000
Re: KAW-A-CIDE
20 Aug 2012 21:25 - 20 Aug 2012 21:28
No eBay APP ID and/or Cert ID defined in Kunena configurationthanks, they were in ok shape but needed to be surfaced. I took them to a local shop where he used a flywheel grinder machine to clean them up. I think the guy on Ebay does the best job Ive seen by miles...I dont Recommend the flywheel approch at all!
Last edit: 20 Aug 2012 21:28 by 4TheKZ1000.
- 4TheKZ1000
- sc/ant864
Re: KAW-A-CIDE ....... RELOADED
09 Oct 2012 00:28
Nice man! Is that VDO liquid filled?
streetstrip project
'77KZ900/1000
'88Mustang GT
'77KZ900/1000
'88Mustang GT
- 4TheKZ1000
09 Oct 2012 00:29sc/ant864 wrote: Nice man! Is that VDO liquid filled?
NO...but works very smooth...no vibes...
