1981 kz1100 followed me home.
- kzcurt
09 Aug 2012 17:35 - 11 Aug 2012 11:23
This '81 KZ1100 just followed me home yesterday, so i thought i would keep it! It was a trade for work kinda thing around '6 month's, then 'about a year ago'... the guy i bought it from said it was inside till then in an old ladies barn. I'm finding clutch cable, brakes, throttle return seem to all be frozen...hmmm :huh: Now I'm kind of worried that he was saying the engine wasn't frozen!!!
He also said he had it started right up when he brought it home 'just put gas and battery in and it started right up, ran great!!...'
he had a straight face too
:laugh:
Flag carrier #23
9 @ 50-2053,
9 @ 50-2053,
Last edit: 11 Aug 2012 11:23 by kzcurt.
- Calico
Re: 1981 kz1100 followed me home.
09 Aug 2012 18:06
So I'm at a bit of a loss. Does it not start now? Or are you concerned about trying to? Are the cables the only worry?
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- kzcurt
09 Aug 2012 21:16
the whole bike needs to be scraped clean then i can lube it up, get everything moving freely. it has no battery tires are shot it looks like i might need a new battery cables before i can crank it over. i think ill just get the wheel up, free the clutch cable, an see if i can turn it over in gear.
i was just out there taking the tank off an it looks like the fuel lines only go to 3 of the 4 carbs :woohoo: cant wait to see what those look like inside
OH BOY this is getting exciting :lol:
Flag carrier #23
9 @ 50-2053,
9 @ 50-2053,
- Medina
09 Aug 2012 22:50
Dang, its near MINT!!!
Love the thing, dig the rear sissy bar.
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
Medina, Oh
My Bike Thread
- kzcurt
10 Aug 2012 00:53
exactly!!
that sissy bar has the black carpet on the back even. so cool
Flag carrier #23
9 @ 50-2053,
9 @ 50-2053,
- Calico
10 Aug 2012 11:00
Yeah, that's pretty sweet! Diggin the giant stereo on top! Hey, before ya go tuning the engine, you may wanna top the pistons with something penetrating. Just to be on the safe side of things
81' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
82' KZ750LTD 4 CYL
- les holt
10 Aug 2012 11:17
I had one follow me home bout 8 months ago, turned into a money pit pretty quickly but with pleasurable results. Mine was running but still had to do a top end build on it. :whistle:
It has potential, just get in there and get to it. :laugh:
Les
Les
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
The following user(s) said Thank You: kzcurt
- KZ250LTD
11 Aug 2012 00:48
Might want to check and see if it has a clutch lever lockout. Some KZs will not turn over with elec start without the clutch lever pulled. Also, depending on the carbs, you may be looking at vent hoses, not fuel lines. Often there will be only a single fuel inlet for a rack of carbs and possibly a vacuum line if it is equipped with a vacuum operated petcock.
79 KZ1000ST
Past:
Many.
Past:
Many.
- kzcurt
Re: 1982 kz1100 followed me home.
11 Aug 2012 11:31KZ250LTD wrote: Might want to check and see if it has a clutch lever lockout. Some KZs will not turn over with elec start without the clutch lever pulled. Also, depending on the carbs, you may be looking at vent hoses, not fuel lines. Often there will be only a single fuel inlet for a rack of carbs and possibly a vacuum line if it is equipped with a vacuum operated petcock.
You are right on with the vacuum hoses, I saw that later. this is a much different setup with the vacuum then my 400's I'm used to. I have got a manual on the way, I need that!
I was not aware of the clutch lock out either thanks would have made for a real head scratcher without knowing that. I saw an electric come off the clutch handle an was wondering what its purpose was....
Also checked the title for a VIN an :blush: it's an 82
Flag carrier #23
9 @ 50-2053,
9 @ 50-2053,
- kzcurt
03 Sep 2012 15:13
Ok a little bit further along, or not as far depending on how you look at it?
Attachment IMG_0505.jpg not found
Flag carrier #23
9 @ 50-2053,
9 @ 50-2053,
- kzcurt
03 Sep 2012 15:16
new tires too
Flag carrier #23
9 @ 50-2053,
9 @ 50-2053,
- Motor Head
03 Sep 2012 15:26
Looking good. Are those Shinko tires? Or Kendas?
looks like you have a oil cap on the final drive box?
