74 Z makeover
  • NakedFun
  • NakedFun's Avatar
Re: 74 Z makeover
06 Aug 2012 17:16
#541042
Yeah the 1K ran the same like from like 04-06 I believe? Either way, I know what to look for! Thanks.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • KZ250LTD
  • KZ250LTD's Avatar
Re: 74 Z makeover
06 Aug 2012 17:40
#541046
Very nice old hot rod, looks good!
79 KZ1000ST
Past:
Many.
  • kzz1king
  • kzz1king's Avatar Topic Author
Re: 74 Z makeover
06 Aug 2012 20:00
#541072
Thanks! You guys nailed the taillight. 05 is what it said on ebay for year
Wayne
Home built KZ1000 turbo setup
  • kzz1king
Re: 74 Z makeover
21 May 2013 20:48 - 21 May 2013 20:50
#588596
Well I scored a Kerker on fleabay. It is solid but banged up a bit in the usual places. I need to try any straighten it up a bit in the collector area. It was chrome that has been repainted.I will sand it down and redo it. I figured I saved about $550 over a new one so cant complain. I really like my old V&H pipe but had a rotted out Kerker once that sounded pretty sweet so I will give it a try this summer.
Wayne
Attachment DSCN2598.JPG not found
Attachment DSCN2599.JPG not found
Last edit: 21 May 2013 20:50 by kzz1king.
  • DoctoRot
  • DoctoRot's Avatar
Re: 74 Z makeover
22 May 2013 08:19
#588702
i had a kerker that was pretty dinged up, in the second bend and in the collector. I tried the water trick but its thick enough it didnt work. i took it to a guy that fixes headers for mx bikes. he did a great job for $60. i just need to paint it.
  • kzz1king
Re: 74 Z makeover
22 May 2013 12:27
#588736
DoctoRot wrote: i had a kerker that was pretty dinged up, in the second bend and in the collector. I tried the water trick but its thick enough it didnt work. i took it to a guy that fixes headers for mx bikes. he did a great job for $60. i just need to paint it.
What is the water trick? Filling and freezing? It sure does seem stout.
Wayne
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
Re: 74 Z makeover
22 May 2013 15:42
#588767
kzz1king wrote: Hmmmm, you might be unto something!Took me a bit to find it :)
Wayne
Sent you a PM!!
Asking about Memphis Shades!!
My bike is a 1975 Z 900
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • DoctoRot
  • DoctoRot's Avatar
Re: 74 Z makeover
23 May 2013 05:56
#588859
kzz1king wrote: What is the water trick? Filling and freezing? It sure does seem stout.
Wayne
yeah filling with water and letting it freeze. some people swear by it, but i think most of the time its used for 2 stoke expansion chambers. i tried it a couple times and it didnt work. I even had a friend put it in the deep freeze at his work to see if it would be better if it was real cold. no luck. you might try it since it wont cost you anything.
  • kzz1king
Re: 74 Z makeover
09 Aug 2014 15:11
#643248
I got the Kerker fixed up a bit and mounted. I like it. It just has an end cap but sounds pretty mellow until you crack it!
Attachment DSCN3247.jpg not found
Attachment DSCN3248.jpg not found
  • kzz1king
Re: 74 Z makeover
09 Aug 2014 15:11
#643249
Attachment DSCN3247_2014-08-09.jpg not found
Attachment DSCN3248_2014-08-09.jpg not found
The following user(s) said Thank You: floivanus
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 74 Z makeover
09 Aug 2014 15:56
#643257
Ive got a bent frame in the barn that I can cut the rear peg/exhaust hanger bracket off off it you want it. :)
  • kzz1king
Re: 74 Z makeover
09 Aug 2014 16:36
#643260
Don't you like my mount? ;) Thanks for the offer though.
PLUMMEN wrote: Ive got a bent frame in the barn that I can cut the rear peg/exhaust hanger bracket off off it you want it. :)
