Z750 B2 Cafe Build..........Nearly There!!
- 750steve
Re: Z750 B2 Cafe Build..........Nearly There!!
24 Jun 2012 17:54Kapahulu wrote: Nice work Steve!
Thank you, your help came in very handy Mike! Thank you for helping me out with shipping & some goods. Without alot of help from this forum & a couple of others there's no way i could have completed this!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- Kapahulu
24 Jun 2012 21:01
Glad I was able to help out. If you ever need to put a large order together again let me know.
Here's one of my KZ's .
Still working on the other two. Well, actually all three of them are works in progress.
2strokeworld.com
2strokeworld.com
- 750steve
24 Jun 2012 21:59
Dude that is 1 SERIOUS Yoshi!! Love the build! BIG change from when you got it!!!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- Motor Head
01 Jul 2012 13:19 - 01 Jul 2012 13:20
Don't know how, but I missed this post and just had a squiz. Sounds and looks Mean there Steve! :woohoo:
That will get some adrenalin pumping!!
I would change my Avatar Photo to that!
Last edit: 01 Jul 2012 13:20 by Motor Head.
- 750steve
01 Jul 2012 13:49 - 01 Jul 2012 13:50Motor Head wrote: Don't know how, but I missed this post and just had a squiz. Sounds and looks Mean there Steve! :woohoo:
Thanks MH! You, personally, were a big help in me getting to this stage, remember the starter motor problem i was having months ago at the beginning?, that was before i stripped the bike down! Seems a long time ago now!! I appreciate all the help, thank you.
I'll change my avatar pic to my bike but i want to change a few things 1st.........the bars look too high so i would like to replace them with clip-ons, i might try a bigger light as well to see how that works, the clutch cable needs shortened & i need a clutch cover gasket & generator cover gasket as i have a couple of minor leaks. Oh yeah, i need to replace the oil sight glass window too as even though i cleaned it i can see nothing, i dunno why cos it looks reasonably clean, the oil doesn't seem to be getting through the 'holes' in the metal late behind! I put 4L of oil in with a new filter so i know the level should be ok but i don't like guess work when it comes to that kinda thing
Those gaskets aren't made now, where can i buy pattern ones? Any idea's
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 01 Jul 2012 13:50 by 750steve.
- Motor Head
01 Jul 2012 14:17 - 01 Jul 2012 14:51
You can be fooled sometimes by the clean oil, you might be looking right through to the back side of the sight window. Try looking in there and leaning the bike over slightly, and see if you can spot the oil. I know for me after a change, I have to look pretty close at it, Old Eyes you know.
those gaskets can be cut from a roll of gasket material, and a gasket hole punch set. Should be pretty easy, you might have trouble on the first, but it will soon be easy to make them.
"remember the starter motor problem i was having months ago at the beginning?"
Oh yes I do, that was a strange sound it made, but seems an easy fix once the little stake pin was secured in place.
Last edit: 01 Jul 2012 14:51 by Motor Head.
- 750steve
01 Jul 2012 15:17Tried & leaned the bike over, still nothing! Definately need to replave the glassMotor Head wrote: You can be fooled sometimes by the clean oil, you might be looking right through to the back side of the sight window. Try looking in there and leaning the bike over slightly, and see if you can spot the oil. I know for me after a change, I have to look pretty close at it, Old Eyes you know.
Ah but it popped out again so i used bearing seal for that larger outer gear & its holding up very well, seriously strong stuff!!Motor Head wrote: "remember the starter motor problem i was having months ago at the beginning?"
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- damarble
01 Jul 2012 15:19
I like it. I normally don't care for cafe style tails but your design looks good.
My on concern is that sharp lip at the back of the tank. That's going to hurt during hard stops if you don't brace yourself. Luckily you wont have a passenger to slam you into it!
Go green, buy a Kawasaki!
82 KZ750M CSR Build Thread
89 ZX600C Streetfighter
- 750steve
18 Aug 2012 15:08
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- Rainman
- and a little Kaw shall lead them
18 Aug 2012 17:20
Nice work, Steve, Clean and simple. Like the pipes.
Jim
Jim
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Jim
Quincy,IL
- 750steve
18 Aug 2012 17:23
Some more bits'n'bobs
Trial fit for a few things
Some nickel plating, GREAT value, £15 for a whole sweetie box full & the engine mounts & axles!!!
A few essential bits of bent metal
Some painting.......1st the engine
Then the tank, done in the multitasking garage......note the couple of little holes where the badges go that needed welded up.
& a friend done the lacquering, £20 well spent as he does car bodywork. I painted the tank has a run, stripped it back & done it again, then the lacquer ran.........painted it AGAIN & no way was i doing the lacquer!!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- 300
07 Sep 2012 00:49
hi there! great work !!! i have some questions:
I want to paint my engine too but everybody is telling me that will overheat the engine, is that true? did you notice something like that on yours? what kind of paint should i use?
Any help will be appreciated
