KZ 250 Ltd D1
  • Atraeu
  • Atraeu's Avatar Topic Author
KZ 250 Ltd D1
15 Jun 2012 20:23
#529424
Grabbed this lil gem for $75 after it had a 20yr nap in a barn however I learned that despite the factory oil filter haveing managed to stay with it for 7k miles and 32 yrs the factory air filter cap on these bikes seems to have been taken do to a strange conspiracy lol but if anyone has a spare or could get mi some dimensions and pics would be great but all in all what yall think for a $75 bike that still drives with 7k miles
It is time to order more signatures please contact Jimbo at Metro signatures and fortunes llc.
250 Ltd
Custom 1100
Re: KZ 250 Ltd D1
15 Jun 2012 22:40 - 15 Jun 2012 22:41
#529455
$75 is a steal! Which bits do you need? (see diagram below)
Attachment 00000_2012-06-15.jpg not found
Last edit: 15 Jun 2012 22:41 by 650ed.
  • Atraeu
Re: KZ 250 Ltd D1
17 Jun 2012 02:33 - 17 Jun 2012 02:35
#529780
Yea found it on craigslist was on the way to pick it up in under an hour was really happy when it passed me on the way there lol
In the diagram missing number 2 and 3 11012-1103 cap air filter and of course the filter itself 11013-1030
250 Ltd
Custom 1100
Last edit: 17 Jun 2012 02:35 by Atraeu.
  • sham
  • sham's Avatar
Re: KZ 250 Ltd D1
17 Jun 2012 09:52
#529813
Hey,
Great to see another 250.
I've got your missing 2 and 3, but no air filter.
In my research, I found the following and wrote it up elsewhere:
The OEM air filter element has been superceded but kawasaki didn't update the code, the same part can now be found under this code 11013-1039, and fits the kz250 as well as the following models:
KZ250-D1 (KZ250) (1980)
KZ250-D2 (CSR) (1981)
KZ250-L1 (CSR Belt) (1982)
KZ305-A1 (CSR) (1981)
KZ305-A2 (CSR) (1982)
KZ305-B1 (CSR Belt) (1982)
KZ305-B2 (LTD) (1987)
KZ305-B3 (LTD) (1988)
Original post here - www.kawasakimotorcycle.org/forum/vintage...filter-81-kz250.html
The following user(s) said Thank You: Motor Head
  • bluej58
  • bluej58's Avatar
Re: KZ 250 Ltd D1
17 Jun 2012 10:26
#529817
Nice score, I'd like to find one of those for my wife, right now we're looking at Rebels
JD
78 KZ1000 A2A
  • Atraeu
Re: KZ 250 Ltd D1
17 Jun 2012 14:04
#529868
I could kiss u sham how much u want?
250 Ltd
Custom 1100
  • sham
  • sham's Avatar
Re: KZ 250 Ltd D1
19 Jun 2012 10:04
#530302
Lol replied to your pm.
  • Atraeu
Re: KZ 250 Ltd D1
29 Jun 2012 20:31
#532696
Figured would stop in for an update and a lil question today received mi new air filter cap, air filter, rh side cover tach cable horn, front brake cable and switch (best part all that bought and shipped for $60) took out for a lil 4 mile workout and runs great but the spark plug is black like I am running rich despite the lack of a muffler (guess what I forgot to order) should make it lean right? And other than black plug was new no other rich symptoms revs smooth hit 70mph real easy so another ideas what would cause the carbon not oil fouled plug with out presenting notable symptoms
250 Ltd
Custom 1100
  • sham
  • sham's Avatar
Re: KZ 250 Ltd D1
30 Jun 2012 07:20
#532753
Looks like we're sharing one problem at least - my plug is totally fouled from dry carbon too. Bike is pretty much not starting again because of it. While I haven't had time to do so yet, I am planning to check how much power I'm getting at the coils - wiredgeorge has a mod to help improve this if you're not getting 12.4V. Under powdered coils are supposedly a reason for the carbon build up if your bike isn't running rich and has good compression (check valve clearances).
Btw did you get the air filter element as well? I'm thinking of ordering it in incase I want to run the original air box. Glad you got all that for so cheap and so quickly btw - would have taken ages from this end.
  • Atraeu
Re: KZ 250 Ltd D1
30 Jun 2012 13:21
#532796
Well now that I think about it that is quite possible going to have to check the coil voltage 32 yr old wire can build resistance as far s the filter it is actually just the one that was in the cap I got it was just in really good shape so cleaned it double checked for holes and went for it
250 Ltd
Custom 1100
  • sham
  • sham's Avatar
Re: KZ 250 Ltd D1
02 Jul 2012 10:05
#533292
Ha nice.
Here's the link to the WG solution : www.wgcarbs.com//index.php?option=com_co...view&id=12&Itemid=26
But a quick search through the forum does yield different opinions.
If you are planning to redo the wiring and don't have a manual, I've got one with the wiring diagrams etc, so let me know.
  • Atraeu
Re: KZ 250 Ltd D1
02 Jul 2012 11:13
#533313
Oddly with everything that went missing from mi bike I found the owners manual all its dealer paperwork and its last registration
250 Ltd
Custom 1100
