1981 kz1000c-4 large starter gear bearing
  • Charles Nix
  • Charles Nix's Avatar Topic Author
  • 1981 kz 1000c4
24 May 2012 13:38
#524538
Attachment chelseaspicturesfromipod1308.jpg not found
Attachment chelseaspicturesfromipod1305.jpg not found
[img]http://[/img]
Does the gaps on these low mile bearings look normal for 24,000 miles?
These are for crankshaft gear.
  • Motor Head
  • Motor Head's Avatar
Re: 1981 kz1000c-4 large starter gear bearing
24 May 2012 22:47
#524619
I believe that is where the cage has a seem, as they roll the cage to shape it. The needle rollers and the clearance is the concern.
  • Charles Nix
  • 1981 kz 1000c4
24 May 2012 22:57
#524620
Thanks Motorhead,i would suspect that they would get another 24,000 miles. Now all I need is to get me a big starter gear.
  • MFolks
  • MFolks's Avatar
24 May 2012 23:27
#524626
For a starter with much better torque, read this:
Using a Honda Mitsuba SM-220 Starter in the Kz (copied from the KZ rider website)
The CB F's used 2 different starters. Look for the one marked .8kw. They also have one that is .7kw. The owner noticed a difference when he installed his. He read that you can remove the outer housing, and rotate it. this will re-align the outer power terminal, to a better location. if you don’t do this, you will need to grind some metal from the chain cover to gain clearance. Also install a heavier gauge wire to the starter .
The stock KZ starter is .6kw in size
www.stockers.com/index.php?dt=HS-29 (Mitsuba SM-220)
  • Charles Nix
  • 1981 kz 1000c4
25 May 2012 00:51
#524633
Thanks Mike folks,that is a good one for sure!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
25 May 2012 17:25 - 25 May 2012 17:25
#524769
Or, u can get 1 of those starters from Ebay for $30. :)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 May 2012 17:25 by mark1122.
