Gone Fishing
- DesmoBro
- ~Building a Fish~
Gone Fishing
22 May 2012 17:39
Traded the Snowblower (can't stand looking at it standing idle all summer)....Scored an 82 KZ750 With issues but hey I can fix things...Ish,Right?
www.dotheton.com/forum/index.php?topic=34163.0
~~^^Fish in Progress^^~~
- DesmoBro
- ~Building a Fish~
Re: Gone Fishing
22 May 2012 17:44
This turned from me trying to fix the bike into how many tools can I fit in the basement.
- DesmoBro
- ~Building a Fish~
Re: Gone Fishing
23 Jul 2012 22:55
Ok so i got this beast back together but my Timing adavancer is fucked i can't even get the phillips heads off to get to it.... Any ideas?
Re: Gone Fishing
23 Jul 2012 23:03
2 ideas:
1. Soak the screws for a couple days with Kroil. It will help break the bond between them and the engine case. If you cannot find it locally you can buy it directly from the manufacturer:
www.kanolabs.com/
or here;
www.amazon.com/Kano-Kroil-Penetrating-li...-KROIL/dp/B000F09CF4
2. They are not Phillips screws. They, like all the cross head screws on KZs are JIS screws. Here's more about them:
kzrider.com/forum/21-tools/532335-budget...ewdriver-tips#532335
www.kanolabs.com/
or here;
- trianglelaguna
Re: Gone Fishing
23 Jul 2012 23:09
vise grips and the best bite you can get after the soaking
or if that dont work and you booger it more
drill it and tap a easyout bolt extractor in if that fails...then use a wrench on the square easyout shank straight and slow....but if you put the vise grip on straight and very tight clamped...they will turn out
oh and you'll need new screws..da
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- DesmoBro
- ~Building a Fish~
Re: Gone Fishing
23 Jul 2012 23:27
Thanks Guys I did Try Vise Grips Maybe I need a New Pair? I have had luck with them in a similar situation but here they are kind of bulky to get in there
Re: Gone Fishing
24 Jul 2012 00:19
After the Kroil treatment, could heat screw head with propane torch, and use a hand-held impact driver.
- DesmoBro
- ~Building a Fish~
Re: Gone Fishing
24 Jul 2012 21:18
Took a Dremel to the 3 JIS screws made them into flat heads...Heated them up(propane) and with a 12v drill & flathead bit all three came right off.....Got the timing advancer moving as it should And Installed it On bike.....RUNS 100% percent better thanks guys!Went for a nice long drive....Only thing i noticed is @ 6,000 rpm it's a lil hesitant and burbly in the lower gears in the higher gears it causes it to not go past that unless i down shift....Could this be the timing is off a little bit?
