New Build
  • Dvrmerck
  • Dvrmerck's Avatar Topic Author
New Build
24 Apr 2012 00:26
#517682
I have disassembled my bike but do noit know where to start. Minor modifications of frame, rebuild forks or start buying product? Any ideas?
  • ramtough_63
  • ramtough_63's Avatar
Re: New Build
24 Apr 2012 00:36
#517689
get an idea of what you want. Look at different builds whats your objective? I would normally advise you to have an idea before you disassemble anything.
keep in mind most builds change several times during the process. mine started out as a get it running and ride it project. went from wanting a wider rear tire to a monoshock conversion.
I got my original inspiration from a KZ i found on Youtube now it's not even close.
Whats your motivation and your budget and time frame?? that will definately help on where to start
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Re: New Build
24 Apr 2012 00:41
#517691
Hello, Dvrmerck, and WELCOME to KZr! :cheer:
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
Attachment addsig.jpg not found
Good Fortune! :)
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: New Build
24 Apr 2012 06:42
#517726
I don't know the level of your skills but if you have no building skills I would go for a restoration. Just painting the bike and assembling will increase your skills.
You will also learn the bike from end to end. Roy
  • Dvrmerck
Re: New Build
21 Dec 2012 20:40
#563961
Forks are together, wheel bearings removed, All Ballz in the freezer cooling, replacing nuts bolts gradually with Stainless fittings. New tires "Spitfires" Rims look great. MOre to follow!
