1979 KZ1000 shaft to chain conversion
Re: 1979 KZ1000 shaft to chain conversion
15 Jun 2020 07:28
you want to source a chain drive version of your engine to source the parts from.
- zed1015
15 Jun 2020 08:17 - 15 Jun 2020 08:17I presume your 79 is a kick start equipped ST engine so the chain output shaft from any z900 or 1000 of the same type kicker motor will do the job.clogan wrote: I know this is an old post but in case your still out there I was wondering could you tell me what donor bike would be best to obtain the output shaft from? I also have a 1979 kz 1000 in need of the chain conversion. Your build is Awesome BTW.. Thanks in advance.
The transmission cover needs to be from a MK2 engine though as the bolt pattern is different earlier engines.
Last edit: 15 Jun 2020 08:17 by zed1015.
