1980 KZ1000P - Project begins.
- JEFFG1
Re: 1980 KZ1000P - Project begins.
04 Mar 2012 21:42
you could go with a dyna s you just wont have the computer there only $143.00
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
- BB
04 Mar 2012 22:33
Dyna S it is. Today was a productive day, I made the following progress:
Removed rear fender
Removed rear shocks, rusted to the point of no return
Removed plastic chain gaurd
Removed rear wheel
Removed front fender and bracket
Removed rear brake caliper, brake line, resevior, floor board and light swith mechanisim
Removed front brake calipers, lines, rear view mirror (attached to brake lever) and brake lever. She now looks like this...
I spent a good 2 hours just staring in bewilderment at the wiring, new, old, cut, shorted, melted, you name it. I did not have the sack to chop it out, thought I would sleep on iy one more night. though long and hard about the recommendations to start the bike first, but with my lack of diagnostic skills, I figure new wiring will significantly reduce the troubleshooting possibilities.
Thanks Guys, more next weekend!
Cheers,
Removed rear fender
Removed rear wheel
Attachment IMG_0135.JPG not found
Attachment IMG_0137.JPG not found
Cheers,
1980 KZ1000P - The Mistress
2002 R1150GS - Matilda
- BB
08 Mar 2012 13:56
Can you guys tell me what these things are... this is on the left side of the battery box.
and this is inder the gas tank, near the forks.
cheers guys,
Attachment IMG_0139.JPG not found
cheers guys,
- BB
08 Mar 2012 13:58Attachment IMG_0140.JPG not found
Sorry, here is the other photo...
- Chaotic Reason
08 Mar 2012 16:37
The first one is your regulator/rectifier. It deals with the power/voltage of your electrical system. Someone else may be better at explaining its purpose.
The second one... I don't know... A doorbell button??? ;Kidding of course.
Michael
1980 KZ1000 shaft drive
- BB
08 Mar 2012 16:42
Thanks man, it could be a doorbell, seems to be the only thing missing from all the wiring. these old cop bikes sure carry a lot of wiring...
08 Mar 2012 17:27
Just wild guessing, but the 2nd one might be the reserve lighting unit (that automatically switches to high bean at slightly lower voltage if the low bean fails.)
Could perhaps i.d. the particular component by the wire colors as shown in a wiring diagram.
- Zedone
08 Mar 2012 22:45
If it were me I'd build the 78 parts bike. It will be easier to sell shd./when the time comes. The police bike looks pretty rough from what I see. You can get an easier selection of parts for the 78 on line than the 80's cop bike. The carbs shd work on either motor (if they are clean)(they shd be 26mm, if there 28mm there off a Z1). Get a compression gauge and see if your in spec. with both motors. Pull the valve covers and post some pics if you can. Don't buy a Dyna 2000 as the other fellows mentioned, spend your money wisely as it will take a fair amount to get it on the road. Your better off getting a repopped wiring harness on-line (it will save you big time head aches). There are a lot of guys on the board with tons help if you get stuck. Keep us posted. Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- BB
09 Mar 2012 00:07
I appreciate the input Zedone. The cop bike actually looks OK to me, bit of rust and corrosion, but all superficial. The plan is to bust it all to bits, powder the frame, rewire from scratch (much simpler) do a full inspection on the engine, chrome bits and pieces and put her back together. Easy right?.............
I know Im biting off a lot, especially as a novice, but no one has ever accused me of half assing anything. I am breaking her into sub projects, they are, the wiring, the engine, fuel, body and brakes. Each a section. This is how it is in my head right now, time will tell. One thing for sure is there is a ton of knowledge and helpful people here. Cheers,
- motorscot
09 Mar 2012 03:43
Stick with the plan you just laid out. With the wiring the way it is, buying a replacement set is a no brainer. Even if you don't use some of the leads, you will be way happier.
www.kawasaki.com/DefaultFrame.aspx?strCo...82%26SHOWVEHTABS%3d1
I have a 85 KZ-P and the wiring is irritating at best. Buy cheap and buy twice. Buy correct and you will have money well spent. Most of the crucial wiring in mine is hard and cracked, hacked up, missing, etc. If I wasn't using it constantly to do escorts, I would re-wire the whole thing.
- BB
09 Mar 2012 13:51
Motorscot - this is brilliant, as we would say in Australia - 'Straight to the pool room'. The earliest model however is the 1982P, can I assume they were the same as the 1980?
- BB
11 Mar 2012 21:39
So she is all apart, here is the puddle of wire
Only one drama, this bolt sheared off, I woudll have to guess it is probably the worst bolt on the entire bike to shear....
So off to the powdercoaters this week. Does anyone have and suggestions for powdercoaters in the Seattle area?
Cheers all,
Attachment IMG_0148.JPG not found
Attachment IMG_0150.JPG not found
Attachment IMG_0160.JPG not found
Attachment IMG_0157.JPG not found
Attachment IMG_0156.JPG not found
Cheers all,
