KZ1000 mild custom, frame off...
  • notaduc
  • notaduc's Avatar Topic Author
01 Feb 2012 22:30 - 29 Apr 2012 20:53
#501436
I have never been good about documenting my projects. I decided to do my best to keep track of this one.
I have a blog that I started a while ago that has become mostly my KZ -
fairmachine.com
I will also try to put some updates here...
A year ago I bought this as a frame/engine and have been grabbing parts on ebay mostly, 18" police wheels, late model police fork/triples, used Kerker, just got some Koni shocks, and a mess of other little things which I am afraid to add up what I have spent...
Currently I am in the middle of the engine overhaul, just reassembled the head after porting and a 4/5 angle valve job.
The frame is out getting blasted (wont fit in our cabinet) so I can refinish it in black oxide.
Here is a BMW oil cooler I welded -6an fittings to yesterday.
1980 (mostly) KZ1000
Last edit: 29 Apr 2012 20:53 by notaduc.
  • porchev914
  • porchev914's Avatar
Re: KZ1000 frame off project.
01 Feb 2012 23:20
#501451
Sweet welds man. Was it was a BMW motorcycle or car?
FRANKEN Z!
  • notaduc
02 Feb 2012 00:24
#501459
Motorcycle. r1100 I believe.
  • porchev914
02 Feb 2012 04:08
#501500
Cool..... I always wondered why you see full braided lines from cooler to engine on the high end bikes like Sanctuary. I'm sure there is a really good reason that I don't know about, but I always thought that it would be cleaner to run a hard line from the engine pick up to the front frame rails, then transition to braided. The braided looks cool and all, but its awfully bulky.
FRANKEN Z!
  • porchev914
02 Feb 2012 04:15
#501502
I can sympathize with your build. I was the exact opposite, I needed to tear the engine apart but I didn't need to tear the rest of the bike down. Once the engine was out though, I couldn't help but give way to the dreams I had about making my KZ a one of a kind (like your Hawk). I got bit hard, and it hasn't let go ;)
Adam
FRANKEN Z!
  • notaduc
02 Feb 2012 11:08
#501528
I was planning on flared hard lines for the cooler, but after talking to our race shop foreman, and our head machinist (who used to do a lot of hydraulic work also), I am going to use flexible lines like most folks use.
They both immediately warned me that the flare like to crack when it sees too much vibration. Its a bummer, I really working with hard line.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
02 Feb 2012 12:39
#501544
i can't wait to see your project come together.
keep us posted
  • notaduc
05 Feb 2012 13:38
#502230
I am in this boring/anxious holding pattern, waiting for my block, pistons and crank to materialize, and the frame to get back from blasting.
I have bee occupying myself cleaning and finishing all the bits I have on hand.
Here are some awesome photos I found of some KZ's at the track for testing in the 70's with honda logos on them.
  • notaduc
05 Feb 2012 13:48 - 05 Feb 2012 13:49
#502232
The machine work on my head is finished, and its painted waiting in a bag on the shelf.
Here is a photo of the plugs in my smog ports, I posted this as a reply to another thread, but as its part of my project...
I wanted to run the early valve cover, so, I turned four tapered aluminum plugs and welded them into the openings in the exhaust ports before the porting happened. In the photo above, I tapped the upper holes 1/8 NPT, and put some plugs in more for cosmetics and to keep water and debris out.
Last edit: 05 Feb 2012 13:49 by notaduc.
  • notaduc
14 Feb 2012 21:50 - 14 Feb 2012 21:53
#504044
This will be full of tweeky little projects, like this.
Starter hole plug with npt breather.
Last edit: 14 Feb 2012 21:53 by notaduc.
  • nobody
  • nobody's Avatar
14 Feb 2012 22:31
#504054
:woohoo: hi im a newbe hear, but i like your weld also looks real good .Would also like to see more please. B) also can you tell me how to find info on oil cooler hook up ? again great job !!!!! nobody ohio
  • notaduc
14 Feb 2012 22:45
#504057
Here is some good info on oil coolers
www.oldkawman.com/
Thanks for the compliment, I dont have any other photos of the cooler sorry.
