Project 71 h1500
  • mike9812121298
  • mike9812121298's Avatar Topic Author
Project 71 h1500
26 Jan 2012 14:08
#500179
just thought i would share my new project. it still has tabs from 83. 74 h1 500. It ran when my dad parked it 30 years ago and it still kicks over. i pulled the carbs off and going to try to clean them up. should i buy a carb kit for them. everything thing seems to work fine? anyways im new to these bikes, is there anything i should look for? or any must replaces? thanks!
  • Drooz
  • Drooz's Avatar
Re: Project 71 h1500
26 Jan 2012 14:40
#500182
You should hook up with these guys!
kawi2strokes.com/forum/index.php?sid=96e...55fc636598753cb57d83
They'll help you get going! B)
'77 kz1000 (zx10r) Modified/Street
'81 GPz550 "TrackBike"
'05 zx10r Retro/Mod Sportbike 4 SALE!!
'02 zrx1200r Lightly Modified Street SOLD!!
'74 h2b 750 (FZ600) "Mongrel" 2 Stroke SOLD!!
"Invictus Maneo" - I remain unvanquished.
Kawasaki - Let The Good Times Roll!
Mississauga, Ontario. CANADA
  • KraZyRIDER
  • KraZyRIDER's Avatar
26 Jan 2012 23:14
#500256
...it shouldn't take much at all to get it running. Those 2 strokes are the simplest of engines to work on. Pull the carbs, blast them with a can of carb cleaned, inside and out. Hit ever hole and passage with the cleaner. Make sure the floats swing free and the needles open and close with the drop of the floats. Dump the old gas and old 2 stroke oil for new. Drop in a fresh set of plugs, open the throttle all the way, squirt a little bit of carb cleaner through each carb, close the throttle, turn on the key, hold down the enriching button and kick it through. Don't be surprised if it starts on the first, or second kick. The carb cleaner will act as starting fluid.
...mind you, that's just to get it running. The carbs will need to be set up. You should probably pull the exhaust baffles and clean the crud off of them. Make sure to unplug any little holes in the baffles. You don't want to cut down your exhaust flow.
...once you get that baby rollin', take her out on a nice straight street with no traffic, or people around. Pull in the clutch, drop 'er in first, crack that throttle 'til she's singin' at 4 grand, drop that clutch and hold on for dear life. That back wheel will start spinnin' and smokin'. Just get ready for when she hooks up and starts pointin' that front wheel towards the stars! Run through the gears and thank your Dad for hangin' on to such a classic.
...I can smell that rubber and 2 stroke oil already. ;)
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
  • ramtough_63
  • ramtough_63's Avatar
26 Jan 2012 23:29
#500257
very very cool keep us posted for sure
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
